Compactness of the unit ball in infinite dimension
In infinite dimensional normed linear spaces, the closed unit ball is never compact, a fact established through the Riesz lemma. This lemma provides a method to demonstrate the non-compactness by showing that any open cover of the unit ball cannot be reduced to a finite subcover without leading to contradictions regarding dimensionality. Specifically, if the unit ball were compact, it would imply that the space is finite dimensional, which contradicts the assumption of infinite dimensionality. The discussion highlights various proofs and intuitive ideas surrounding this fundamental concept in functional analysis.
  • Understanding of normed linear spaces
  • Familiarity with the Riesz lemma
  • Basic knowledge of Hilbert spaces
  • Concept of compactness in topology
  • Study the Riesz lemma and its applications in functional analysis
  • Explore the properties of Hilbert spaces and their implications for compactness
  • Learn about the concept of local compactness in normed spaces
  • Investigate the relationship between compactness and dimensionality in various mathematical contexts
Mathematicians, students of functional analysis, and anyone interested in the properties of infinite dimensional spaces and their implications for topology and analysis.
quasar987
Is it a fact that in an infinite dimensional normed linear space, the closed unit ball is never compact?
If so, how does one go about seeing this?
That's right. The compactness of the closed unit ball (in the norm topology) characterizes finite-dimensionality.
You can prove that the ball is not compact in an infinite dimensional space by invoking the Riesz lemma. (This is one of many ways.)
Any other way comes to mind? I wonder if I can prove this with what I know.
What can you work with?
There's a really easy proof for Hilbert spaces (elements of an infinite o.n. set are a distance of sqrt(2) apart).
An idea: proving that the ball is dense in the whole space by means of showing the only functional null on the ball is the identically null functionnal.
(How can elements of an infinite o.n. set be a distance of sqrt(2) apart in the case where the set is a basis and hence dense?)
mmh my idea does not work directly... because I just double checked and this criterion for density applies to subspaces only.
And it doesn'T make sense that the ball be dense, since it's closed, it would be the whole space, which it obviously isnt. :p
Why would this be a problem? If e and f are two distinct elements in any o.n. set, then ||e - f||^2 = <e-f, e-f> = ||e||^2 + ||f||^2 = 2.
By the way, the most elementary way to prove this is to use the Riesz lemma. In fact the Riesz lemma basically tells you how to do the Hilbert space trick when you don't have an inner product: it let's you find a vector that's 'nearly' orthogonal to any proper subspace.
Alright, I'll look into it. There's a nice wiki page about including a proof.
There is a quite simple intuitive idea behind this, which also leads towards one possible proof. It goes like this:
Let E be a norm space, and B(0,1) the unit ball. Let us assume B(0,1) is compact. Since {B(x,1/2) | ||x|| < 1} is an open cover for the unit ball, there exists a finite number of points x_k so that
<br /> B(0,1) \subset \bigcup_{k=1}^N B(x_k, \frac{1}{2}).<br />
Now there is two alternatives. Either the x_k span the space E, <x_1,...,x_N>=E, or then they don't. If they do, E is finite dimensional, and we are done. If they do not span, then we end up into a contradiction because the ball B(0,1) has points that have distance greater than 1/2 from the spanned subspace.
You can convince yourself of this by drawing a two dimensional picture. Pretend that x-axis describes the subspace <x_1,...,x_N>, and y-axis some non spanned direction. If you draw a ball x^2+y^2 < 1, you'll see it contains points that have distance greater than 1/2 from the x-axis.
if you read the book of dieudonne on foundations of modern analysis, you will find this and other beautiful results in the early chapters. in the 1960's this was taught in basic honors advanced calculus.
Well it's not in the chapter on normed space (ch. 5). Are you sure you've got the right book?
look at thm 5.9.4 page 109.
I see! "A locally compact normed space is finite dimensional."
If the closed unit ball were compact, every closed ball would be too, and hence the space would be locally compact, and hence finite dimensional
  • · Replies 66 ·
  • · Replies 16 ·
