Comparison test for series convergence (trig function)
6 replies · 5K views
kwal0203
Use a comparison test to determine whether this series converges:
[tex]\sum_{x=1}^{\infty }\sin ^2(\frac{1}{x})[/tex]
At small values of x:
[tex]\sin x\approx x[/tex]
[tex]a_{x}=\sin \frac{1}{x}[/tex]
[tex]b_{x}=\frac{1}{x}[/tex]
[tex]\lim \frac{a_{x}}{b_{x}}=\frac{\sin \frac{1}{x}}{\frac{1}{x}}=1[/tex]
Since 1/x diverges so does sin(1/x).
Can I use this same method to solve the question above? ( i.e. sin^2(1/x) )
Why not just try out that same method? What can you compare sin2(1/x) to?
I guess what I'm not sure about is if this is true:
[tex]\sin^2 x\approx x^{2}[/tex]
Can I just make that assumption?
[tex]\sin x\approx x^{2}[/tex]
No, reckless assumption often leads to errors. Do you recall that special trigonometric limit that involves sin? It involves a limit where x tends to 0 but with a clever use of substitution it may help you.
Hmm, what about this, if:
then
Since I'm just squaring both sides it should still be true right?
Then I can go:
[tex]a_{x}=\sin ^2\frac{1}{x}[/tex]
[tex]b_{x}=\frac{1}{x^2}[/tex]
It does work out this way, but what function did you have in mind to compare it to?
then
Then I can go:
You shouldn't use approximations as they don't have a place in mathematical problems of this nature and they don't mean anything without specifying a tolerance for error. sin(pi) is approximately equal to pi like 5 is approximately equal to 2
The limit I was referring to is lim x --> 0 (sinx/x) = 1. Try and figure out its application to this problem.
[tex]\sin x\leqslant 1[/tex]
[tex]\frac{\sin x}{x^{2}}\leqslant \frac{1}{x^{2}}[/tex]
[tex]\frac{\sin^2 x}{x^{2}}\leqslant \sin(\frac{1}{x^{2}})[/tex]
Am I on the right track here?
Sorry, I'm not really sure how sin(x)/x relates to sin^2(1/x) in terms of which is greater than the other. How can I figure that out?
