Compiles, and motor driver shields work individually--but not together
The forum discussion addresses an issue with the simultaneous operation of two X-NUCLEO-IHM02A1 motor driver shields using Mbed's code. While both shields function independently, they fail to operate together when initialized in the same program. The user provides a minimum reproducible example of the code, which compiles without warnings but results in no motor movement when both shields are loaded. The discussion highlights the need for troubleshooting the initialization and communication between the two motor driver shields.
  • Familiarity with Mbed OS and its online IDE.
  • Understanding of SPI communication protocols.
  • Knowledge of stepper motor control and configurations.
  • Experience with C++ programming, particularly in embedded systems.
  • Investigate the initialization sequence for multiple X-NUCLEO-IHM02A1 shields.
  • Learn about SPI bus sharing and potential conflicts in motor driver configurations.
  • Explore debugging techniques for embedded systems without a debugger.
  • Review the hardware documentation for the X-NUCLEO-IHM02A1 for any limitations on simultaneous use.
Embedded systems developers, robotics engineers, and hobbyists working with motor control applications using Mbed and X-NUCLEO motor driver shields.
adamaero
TL;DR
I'm using an STM32F767 MCU along with two shields: IHM02A1 dual stepper motor driver.
I don't have a debugger yet, but my company is getting one...
In the mean time, I've been un/commenting out parts of Mbed's code. Their Hello World program is available from this website, and it can be used directly in their online IDE by clicking "Import Program": https://os.mbed.com/components/X-NUCLEO-IHM03A1/
Code:
#include "mbed.h"
#include "DevSPI.h"
#include "XNucleoIHM02A1.h"
#define MPR_1 4 /* Number of movements per revolution. */
#define STEPS_1 (200 * 128)   /* 1 revolution given a 200 steps motor configured at 1/128 microstep mode. */
#define STEPS_2 (STEPS_1 * 2)
/* Delay in milliseconds. */
#define DELAY_1 1000
#define DELAY_2 2000
#define DELAY_3 3000
/* Motor Control Expansion Board. */
XNucleoIHM02A1 *x_nucleo_ihm02a1;
XNucleoIHM02A1 *x_nucleo_ihm02a1two;
/* Initialization parameters of the motors connected to the expansion board. */
L6470_init_t init[L6470DAISYCHAINSIZE] = {
    /* First Motor. */
        24.0,                          /* Motor supply voltage in V. */
        200,                           /* Min number of steps per revolution for the motor. */
        1.7,                           /* Max motor phase voltage in A. */
        3.06,                          /* Max motor phase voltage in V. */
        300.0,                         /* Motor initial speed [step/s]. */
        500.0,                         /* Motor acceleration [step/s^2] (comment for infinite acceleration mode). */
        500.0,                         /* Motor deceleration [step/s^2] (comment for infinite deceleration mode). */
        992.0,                         /* Motor maximum speed [step/s]. */
        0.0,                           /* Motor minimum speed [step/s]. */
        602.7,                         /* Motor full-step speed threshold [step/s]. */
        3.06,                          /* Holding kval [V]. */
        3.06,                          /* Constant speed kval [V]. */
        3.06,                          /* Acceleration starting kval [V]. */
        3.06,                          /* Deceleration starting kval [V]. */
        61.52,                         /* Intersect speed for bemf compensation curve slope changing [step/s]. */
        392.1569e-6,                   /* Start slope [s/step]. */
        643.1372e-6,                   /* Acceleration final slope [s/step]. */
        643.1372e-6,                   /* Deceleration final slope [s/step]. */
        0,                             /* Thermal compensation factor (range [0, 15]). */
        3.06 * 1000 * 1.10,            /* Ocd threshold [ma] (range [375 ma, 6000 ma]). */
        3.06 * 1000 * 1.00,            /* Stall threshold [ma] (range [31.25 ma, 4000 ma]). */
        StepperMotor::STEP_MODE_1_128, /* Step mode selection. */
        0xFF,                          /* Alarm conditions enable. */
        0x2E88                         /* Ic configuration. */
    /* Second Motor. */
int main()
    /* Initializing SPI bus. */
#ifdef TARGET_STM32F429
    DevSPI dev_spi(D11, D12, D13);
#else
#endif
    /* Initializing Motor Control Expansion Board. */
    x_nucleo_ihm02a1 =    new XNucleoIHM02A1(&init[0], &init[1], A4, A5, D4, D2, &dev_spi);
    x_nucleo_ihm02a1two = new XNucleoIHM02A1(&init[0], &init[1], A4, A5, D4, A2, &dev_spi);
    /* Building a list of motor control components. */
    L6470 **motors = x_nucleo_ihm02a1->get_components();
    L6470 **motorstwo = x_nucleo_ihm02a1two->get_components();
    /* Setting the home position. */
    //motorstwo[1]->set_home();
//    wait_ms(DELAY_1);
    int position = motorstwo[1]->get_position();
    wait_ms(DELAY_1);
//      motors[1]->move(StepperMotor::FWD, STEPS_2);
//      motors[0]->move(StepperMotor::FWD, STEPS_2);
//    wait_ms(DELAY_2);
      motorstwo[1]->move(StepperMotor::FWD, STEPS_2);
      motorstwo[0]->move(StepperMotor::FWD, STEPS_2);
    wait_ms(DELAY_1);
That's a minimum reproducible example of the full program. If you want to try it out yourself, simply copy/paste it into main.cpp (in the online IDE noted above).
Everything complies, no warnings. Either of the lines below (with their matching pointers and such) works by moving the motors. I.e., motorstwo[x] and motors[x] both work out on their own. But when both lines are loaded unto the board...nothing works, the motors do not move. The steppers don't even have a very soft sound coming from them.
Code:
Why can't these two lines be uploaded together? How can this be fixed? Thanks.
Technology news on Phys.org
