Completing the square (How to)
  • Thread starter Thread starter danielle36
    Square
17 replies · 5K views · last reply
danielle36
Here's the problem I'm currently working on:
x[tex]^{2}[/tex] + 6x + 1 = 0
Solve.
Now I'm supposed to be learning completing the square here and the textbook I have to work with doesn't quite explain it in much detail - so I don't know that I've even got the whole concept on how to complete the square.
This is what I've done, which will end up giving me the wrong answer.
[tex]x^{2} + 6x + 1 = 0[/tex]
[tex]x^{2} + 6x + 1 + 8 = 8[/tex]
[tex](x + 3)^{2}= 8[/tex]
[tex]\sqrt{(x+ 3)^{2}}[/tex] = [tex]+ or -\sqrt{8}[/tex]
[tex]x = \sqrt{8} - or + 3[/tex]
I'm really just following an example given from the textbook, to tell the truth I have no idea if the concept actually applies to this situation or not.
The answer is supposed to be
[tex]x = -3 + or - 2 \sqrt{2}[/tex]
when you have
x+3 = +/- sqrt(8),
the next step is x = -3 +/- sqrt(8)
so I don't understand how you end up with sqrt(8) +/- 3
By the way sqrt(8) = 2sqrt(2).
Completing the square comes from:
[tex](x+a)^2 = x^2+2ax+a^2[/tex]
[tex](x+a)^2 - a^2 = x^2+2ax[/tex]
I'm sure the text probably introduced it in that manner. In that case what are you stuck on specifically?
This line is wrong. You don't square root it. Square root something will only return you a non-negative value.
Say, if a2 = 16, then [tex]\sqrt{a ^ 2} = |a| = 4[/tex]
What you should do is just leave out the square sign, like this:
[tex](x + 3) ^ 2 = 8[/tex]
[tex]\Rightarrow x + 3 = \pm \sqrt{8}[/tex]
i.e, (x + 3) can have 2 different values (i.e, [tex]\pm \sqrt{8}[/tex]), both of which if you square, you'll get 8.
Can you get it? :)
standard form is
ax^2 + bx + c
which term do you use in "completing the square," ax^2 or bx ? what would your next step me?
rocophysics said:
standard form is
ax^2 + bx + c
Well, he did show his work in the first post. =.=" :rolleyes: He just asked where he had gone wrong. :)
i don't see why you kept working with him, it's wrong from the 2nd line?
Err, sorry, but where is the mistake in the second line? I cannot seem to find one. :frown:
rocophysics said:
x^2 + 6x + 1
(6/2)^2
1 + 8 = (6/2)2 = 9, isn't that correct? He adds 8 to both sides, and comes up with the second line, to get 1 + 8 = 9, as required. Well, I see nothing wrong there. :)
i PM'ed u so that OP doesn't see my solution.
rocophysics said:
x^2 + 6x + 1
(6/2)^2
x^2 + 6x + 1 + 9 = 9
x^2 + 6x + 9 = 8
(x+3)^2 - 8 = 0
f(-3) = (-3)^2 + 6(-3) + 1 = -8
Vertex at (-3,-8)
Just read what the problem asks, does it ask you to find the vertex of the parabola? >"<
Btw, doesn't your third line, and his second line, look exactly the same? They are twins, can't you see? :)
i know they are, i was typing out all my steps (obviously)
ok by reading his again, i thought he had "added" 8 to both sides, my bad
btw, i was "confirming" my answer, get over it.
anyways OP, post 4 is good. i got confused with your 2nd line, oops.
But he has added 8 to both sides. There are many ways to do this, all equivalent, but some people prefer other methods. The OP has added 8 to both sides, whereas others would perhaps add 0(=8-8) to the LHS.
There's no need to take that tone.
oh yes, and since I'm human i took this a little offensive as in implying I'm an idiot not even realizing my lines were the "twins." it's not like i cussed him out. he threw something small at me, so i threw something equivalent, no harm :-]
like i said, get over it. come on now, be realistic. don't make it something bigger than it is.
Can you get it? :)
Well that certainly helped, I had no idea why it was being done in the original example in my text - now it makes sense!
Ok so if [tex]\sqrt{8}[/tex] is the same as [tex]2\sqrt{2}[/tex] then my
answer was basically right except, well except where it was wrong.
So it would look more like:
[tex](x + 3)^{2} = 8[/tex]
[tex](x + 3) = +/- \sqrt {8}[/tex]
[tex]x = +/- \sqrt {8} - 3[/tex]
Would that be correct?
Thats correct. Of course you can simplify [itex]\sqrt{8} = 2 \sqrt{2}[/itex] to get the answer from your text. Have you seen the method I posted before? Sometimes that's easier to use I find if you're not comfortable with the method presented in your book.
Thanks! Your efforts are definitely appreciated! :)
And I did take a look at the other method too, I've got it written down here I'm going to try it out on some more practice problems... once I get beck to my work... I'm in the midst of procrastinating
