Complex Analysis - Proving an inequality
The discussion revolves around proving the inequality 497 ≤ |z³ + 5iz² - 3| ≤ 1503 for |z| = 10 in complex analysis. Participants initially attempted to substitute |z| = 10 into the expression, calculating |1000 + 500i - 3| = 1115.35, which satisfied the upper bound. The triangle inequality was identified as a crucial tool for establishing both bounds, with participants clarifying that |z₁ + z₂| ≤ |z₁| + |z₂| and |z₁ + z₂| ≥ ||z₁| - |z₂|| are key to the proof. Ultimately, the problem was resolved during a tutoring session, highlighting the importance of understanding the application of inequalities in complex analysis.
  • Understanding of complex numbers and their properties
  • Familiarity with the triangle inequality in complex analysis
  • Basic knowledge of modulus and argument of complex numbers
  • Experience with polynomial expressions in complex variables
  • Study the triangle inequality in complex analysis in detail
  • Explore the properties of complex modulus and its applications
  • Learn about polynomial functions of complex variables
  • Practice proving inequalities involving complex numbers
Students studying complex analysis, mathematics educators, and anyone looking to deepen their understanding of inequalities in complex functions.
NewtonianAlch
Show that if |z| = 10 then 497 ≤ |z^{3} + 5iz^{2} − 3| ≤ 1503.
I'm not an entirely sure how to begin this one, or if what I'm doing is correct.
If I sub in |z| = 10 into the equation; |1000 + 500i - 3| = 997 +500i
Then the modulus of that is sqrt(997^{2}+500^{2}) = 1115.35
497 ≤ 1115.35 ≤ 1503
You subbed in z=10, but there are many other values of z with |z|=10 (for example, 10i, 5sqrt(2)+5sqrt(2)i, etc.)
You just have to apply the triangle inequality (in a different form for each bound)
I took a look at triangle inequalities for Complex Analysis, and there are essentially two types?
One for the upper bound and one for the lower:
|z1 + z2| ≤ |z1| + |z2|
|z1 + z2| ≥ ||z1| − |z2||
But I'm not too sure how that would fit in here.
Would I need to find the roots of z as a starting point?
For example, from this you can also show
| z_1 + z_2 + z_3 | \leq |z_1| + |z_2| + |z_3|
It's really not clicking still.
So I'm meant to show 497 ≤ |z1| + |z2| + |z3|, so would z1 = z^3, z2 = 5iz^2, and z3 = -3 ?
That wouldn't prove anything, since 497 ≤ |z1| + |z2| + |z3| does not imply that 497 ≤ |z1 + z2+ z3|
However, the other direction might be more fruitful
OK.
|z1 + z2 + z3| \geq 497
z1 = z^3
z2 = 5iz^2
z3 = -3
z^3 + 5iz^2 \geq 500
|z| = 10, so |z|^2 = 100
Simplifying equation to 1 + 5i \geq 1/2
Am I even remotely in the right direction?
Really appreciate your help by the way. Thanks for that.
I'm still stuck on this problem if anyone can help that'd be great =)
Nvm, it is solved now! Can't believe it was actually very easy, once the tutor did it in class, I was like doh!
