Complex Analysis - Value of Arg[(z-1)/(z+1)] between -pi and pi
The discussion focuses on calculating the argument of the complex expression Arg[(z-1)/(z+1)], where z is a point on the unit circle (|z|=1). It is established that Arg[(z-1)/(z+1)] equals π/2 when the imaginary part of z (Im(z)) is greater than 0, and -π/2 when Im(z) is less than 0. The participants derive this by expressing (z-1)/(z+1) in terms of its real and imaginary components and confirming that it is purely imaginary, leading to the conclusion about the argument's values.
  • Understanding of complex numbers and their representation (a + bi).
  • Familiarity with the unit circle and its properties.
  • Knowledge of the argument function Arg(z) and its geometric interpretation.
  • Ability to manipulate complex fractions and use conjugates for simplification.
  • Study the properties of complex numbers on the unit circle.
  • Learn about the geometric interpretation of the argument of a complex number.
  • Explore the relationship between complex division and the argument function.
  • Investigate the implications of purely imaginary numbers in complex analysis.
Students studying complex analysis, mathematicians interested in the properties of complex functions, and anyone seeking to understand the behavior of arguments in complex numbers.
cooljosh2k2
Let Arg(w) denote that value of the argument between -π and π (inclusive). Show
that:
Arg[(z-1)/(z+1)] = { π/2, if Im(z) > 0 or -π/2 ,if Im(z) < 0.
where z is a point on the unit circle ∣z∣= 1
First, i know that Arg(w) = arctan(b/a) and that Arg(z/w) = Arg(z) - Arg(w).
So Arg[(z-1)/(z+1)] = Arg(z-1) - Arg(z+1).
But then what do i do? I am stuck here. Please help
Note that z is a point of the unit circle. What are its real and imaginary parts? You can find the real and imaginary parts of (z-1)/(z+1) if you multiply both the numerator and denominator with the conjugate of the denominator: z*+1.
ehild
Write z=a+bi.
Can you calculate
\frac{z-1}{z+1}
in terms of a and b?? In particular, can you make the denominator real?
micromass said:
Write z=a+bi.
Can you calculate
\frac{z-1}{z+1}
Is this what I am supposed to do:
(z-1)/(z+1) = (a + bi -1)/(a+bi +1) = (a2 - b2 +2abi -1)/ (a+bi+1)2
Is that right? If so, what do i do next, or if I am wrong, what am i doing wrong?
No, that's not what I get. Just calculate
\frac{a-1+bi}{a+1+bi}=\frac{(a-1+bi)(a+1-bi)}{(a+1+bi)(a+1-bi)}
What do you get??
What do you get??
Ok, i get: (a2+b2+2bi-1)/(a2+b2+2a+1)
Is that right?
Yes, and what is a^2+b^2? (hint: z is on the unit circle).
Can you show that \frac{z-1}{z+1} is purely imaginary?? What are the consequences for the arg?
Wow, am i rusty. I am so embarrassed to say that i don't know. I may be wrong, but i think i faintly remember a^2+b^2= 1. But i don't think its right. As for your other questions, i don't know. I am sorry, I am an idiot.
Yes, a^2+b^2=1. So what does that mean for your equation?
Wow, I am shocked i remembered that lol. It would equal 2bi/(2a +1).
Thanks for helping me through it btw.
OK, so it is
\frac{2b}{2a+1}i
Now calculate the argument. With the arctangent if you prefer.
micromass said:
OK, so it is
\frac{2b}{2a+1}i
How do i do that with 2b and 2a+1?
Well, what is the argument of
0+ci
0+ci
0? My textbook barely even touches on the argument, that's why I am so lost.
Are you still there? I am so confused.
What does your book say that the definition of the Arg is??
"Arg z, the argument of z, defined for z ≠ 0, is the angle which the vector (originating
from 0) to z makes with the positive x-axis. Thus Arg z is defined (modulo
2π) as that number θ for which
cos θ = Re z/|z|
; sin θ = I am z/|z| ."
OK, so the arg is the angle that the vector makes with the x-axis. Now, what angle does ci make with the x-axis?
I don't know what "c" is, am i supposed to come up with a number? Does ci = sinθ?
c is just a real number.
What angle does i make with the x-axis?
I don't know. You make it sound so simple, but I am so confused. I am sorry.
arcsin(Im(z)/|z|)?
Pick a piece of Paper. Draw an x-axis and a y-axis on it. Find the point represented by i. Connect i to 0. What is the angle between the line segment that you've drawn and the x-axis?? Just look at it.
Isnt i on the y-axis? which would make the angle 0.
What is the angle between the x-axis and the y-axis?
OMG, i forgot you said in relation to the x axis. 90 degrees. *hits head*
or pi/2
Yes!
The argument of i is just the angle between i and the x-axis. So, what is the argument of i??
micromass said:
Yes!
pi/2!
And what is the argument of -i??
-pi/2! but how do i go from (2bi)/(2a+1)? do i just ignore the (2b/2a+1)?
  • · Replies 17 ·
  • · Replies 19 ·
