Complex exponentials (simplify the expression)
11 replies · 7K views · last reply
Luongo
1. Simplify ei6x(1+e-i10x)/(1+ei2x)
2. i have no idea how to simplify this its supposed to be in terms of cosines
3. i don't how i can simplify this such that i can use the 1/2(e^x +e^-x) = cosx formula
You need the Euler formula [tex]e^{ix} = \cos x + i \sin x[/tex].
i tried that, i got garbage it MUST be in terms of cosines
You might want to show some work to see where your problem is. (Also you might find [tex]e^{6ix} = e^{5ix} e^{ix}[/tex] useful.)
well, I've multiplied it out i got e^6x+e^-4x and then i did e^2x * e^4x + e^-4x
in the numerator to try to get it in cosine form but i can't get the e^2 out of there so i really have no idea how, can someone show me the steps of simplifying this
You also want to simplify the denominator, so you don't want to multiply the numerator through by the whole [tex]e^{6ix}[/tex] factor. (Also you're leaving out the factors of i in your exponentials, which is a bit confusing, but you shouldn't do it in anything you turn into be graded.)
i got it! you're a genius, how on Earth did you see that??
You know that
[tex]\frac{ e^{ia} + e^{-ia}}{2} = \cos a[/tex]
so if you see
[tex]1 + e^{ib}[/tex]
you want to rewrite that as
[tex]e^{ib/2} ( e^{-ib/2} + e^{ib/2} ).[/tex]
fzero said:
You know that
so if you see
thanks a lot i appreciate it i was hung up on this question for a while :redface:
for simplifying in terms of sines... can i use the same formula except the negative sign is between the 2 expos?
Yes.
