How Can You Simplify the Calculation of a Complex Number Raised to a Power?
The discussion revolves around simplifying the calculation of the complex number z = (1 + (√3/2) + i/2)^24. Participants suggest using De Moivre's theorem and emphasize the importance of accurately determining the angle θ for better results. One user proposes squaring and cubing the expression to facilitate the calculation, while another encourages finding an angle φ such that z can be expressed in exponential form. The conversation highlights the complexity of the problem and the need for a clearer approach to achieve a more elegant solution. Overall, the thread seeks effective methods for simplifying the exponentiation of complex numbers.
TheColector
Member advised to use the homework template for posts in the homework sections of PF.
Hi
I was hoping some of you would give me a clue on how to solve this complex number task.
z = (1 +(√3 /2) + i/2)^24 → x=(1 +(√3 /2), y= 1/2
I think there must be some nice looking way to solve it.
My way was to calculate |z| which was equal to [√(3+2√3)]/2 → cosθ = x/|z|, sinθ= y/|z|
After using De Moivre's formula I got very awful result which was:
z = |z|^24 * (cos(24*θ) + i sin(24*θ))
Can you think of any better looking way to solve this ?
TheColector said:
Hi
Have you tried simply squaring three times and cubing once?
TheColector said:
Hi
Work hard at determining ##\theta## as accurately as you can, because the result may surprise you. (Don't just give one or two decimal places; use as many places as is practical, or---even better----try for an "analytic", closed-form expression.)
TheColector said:
Hi
It's not clear to me what you're trying to do.
It appears that you want to write z in the form of x + iy. If so, x and y would not be as you show them above.
In future posts, don't delete the homework template. Its use is required.
You can gain a lot of insight into the geometry by either squaring or cubing the expression then comparing the real and imaginary parts.
Sorry about deleting it. I won't do so in the future. What I meant with this → was to show the represenstative form of x and iy as a part of "z"
Better yet, consider the quantity that you raise to the 24th power, ##z_1=\frac{\sqrt{3}}{2}+\frac{1}{2}i##. Can you find angle ##\varphi## such that ##z_1=e^{i \varphi}## ? Then raise to the 24th power.
Isn't that effectively what was tried in post #1? And it is 1+½√3+½i.
Looks like TheColector had trouble finding the angle. This is a lot easier after a single squaring or cubing.
haruspex said:
And it is 1+½√3+½i.
Sorry, I misread the parentheses. This makes the problem more interesting.
$$1+\frac{\sqrt{3}}{2}+ \frac{1}{2}i=e^{2i\pi}+e^{i\pi/6}$$
Can you write this as the product of two terms?
(Edited to give less away)
  • · Replies 20 ·
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 18 ·
