Complex Solution to an Exponential Equation
14 replies · 3K views · last reply
cdummie
Solve the following equation: ## (1+a)^n=(1-a)^n## where a is complex number and n is natural number
Euler's formula
I've tried something like this
(1+a)^n=(1-a)^n \\
(\frac{1+a}{1-a})^n=1 ##
But i really have no idea what to do next, since that n-th degree complicates things, i mean i could write a as a= x+iy where x and y are real numbers but it won't help much.
mfb said:
What do you know about numbers z that satisfy zn = 1? In particular, how many are there?
Well, there are n solutions to such equation, ##z=cos\frac{2\pi +2k\pi}{n} + isin\frac{2\pi +2k\pi}{n}##
mfb said:
Right. Using the ##r e^{i \phi}## notation is probably easier in the next steps.
Ok, so, i have ##\frac{1+a}{1-a}=e^{i\frac{2k\pi}{n}}## , but i should find a, what should i do next? Since a is complex number a=x +iy (x, y are real numbers) and then if i multiply and divide LHS by by 1-x +iy it doesn't seem like it gets me any closer to the solution.
Why not? [itex]e^{i\frac{2k\pi}{n}}[/itex] is a constant. If it is bothering you, call it "k". Then [itex]\frac{1+ a}{1- a}= k[/itex] which we can write 1+ a= k(1- a)= k- ka. Can you solve that equation for a? Then, if you need to, write a as x+ iy to solve for x and y.
Well, i think it could go this way:
## 1+a=k-ka \\ a+ka=k-1 \\ a=\frac{k-1}{k+1} \\ a=\frac{e^{i\frac{2k\pi}{n}}-1}{e^{i\frac{2k\pi}{n}}+1} ##
Is this correct?
Is this correct?
Looks on track, but ...
What happens when ##\frac{k}{n}=\frac{1}{2}##?
I think i know what are you trying to say, denominator can't be zero, so this works for every k and n except when n=2k.
Yes, but can you simply that expression you have?
Indeed, because in your derivation you at a point divided by ##e^{i\frac{2k\pi}{n}}+1##, and that doesn't work if that value is 0.
As @PeroK suggested, you can simplify your result.
Let's see, i guess i could multiply numerator and denominator by ## cos\frac{2k\pi}{n} + 1 - sin\frac{2k\pi}{n} ## is this the thing i should do?
mfb said:
There is no need to start with cosine and sine. How can you expand every fraction to make its denominator real?
Well, if it's complex number, i can do that by multiplying with it's conjugate, that's what i did, i can't remember something else.
