What is the acceleration of the garden roller given certain parameters?
  • Thread starter Thread starter PhDorBust
    Motion
The discussion focuses on calculating the acceleration of a garden roller being pulled by a force F at an angle alpha. The setup involves analyzing forces in both the x and y directions, as well as applying the rotational equation of motion. The derived expression for acceleration, which does not include force F, raises concerns about its validity, particularly as it suggests constant acceleration regardless of F's magnitude. Participants express confusion over the absence of F in the final formula and question the logic behind the derived result, indicating a potential error in the calculations. The conversation emphasizes the need for a correct formulation that accurately reflects the influence of the pulling force.
PhDorBust
A garden roller with external radius a is pulled along a rough horizontal path by force F which acts at a point on its axle and is inclined at an angle alpha with the horizontal.
Given that resultant force is at a right angle to F, what is the acceleration of the roller? Express in terms of radius a, alpha, and radius of gyration k.
My set-up (and failure):
Let H be resultant force, f_s is frictional force
Forces in x-dir:
Hsin( \alpha) = Fcos( \alpha) - f_s
Forces in y-dir:
-Hcos( \alpha) = Fsin( \alpha) - mg
Rotational equation of motion:
af_s = \frac{mk^2}{a} \ddot{x}
Assume no slipping:
\ddot{x} = a \ddot{ \theta}
Solve for x-acceleration:
\ddot{x} = \frac{a^2 F - a^2 mgsin( \alpha)}{mk^2 cos( \alpha)}
Correct answer:
\ddot{x} = \frac{ga^2 sin( \alpha) cos( \alpha)}{k^2 + a^2 sin^2 (\alpha)}
Where am I going wrong? I don't see why F isn't in the answer...
I haven't tried to work out the answer myself yet, but you're right that the 'correct answer' looks ridiculous.
It would predict the same acceleration even when F approaches zero, which is ridiculous.
  • · Replies 97 ·
  • · Replies 24 ·
  • · Replies 76 ·
