Components of Earth's angular velocity vector
To find the components of the Earth's angular velocity vector (w) at a latitude of 34 degrees, the discussion emphasizes using a coordinate system where x and y are oriented east and north, respectively, and z points radially outward from the Earth's center. The equations for apparent gravitational acceleration and its components are referenced, but there is uncertainty about how to apply them to determine w. The proposed solution involves projecting w onto the axes, suggesting that w can be expressed as w = wsin(lambda)j + wcos(lambda)k. The conversation also touches on the perceived difficulty of the problem relative to its marking scheme. The discussion ultimately highlights the straightforward nature of the calculations involved.
captainjack2000
Using a coordinate system in whic x and y are due east and nort of the city and z is the radial distance outwards from te centre of te earth, find the compnents of w the Earth's angular velocity vector. You may assume that the latitude of the city is lamdba = 34degrees.
I know that apparent gravitational acceleration g*=g-w x (w x r) and that gh* = w^2 rsin(lambda)cos(lambda) and gv* = g-w^2 r sin(lambda)^2. But I am not sure how to fit this all together to find w
Any suggestions or help much appreciated!
the diagram for this is in the notes. chapter 5 page 4. w is going vertically upward, mark on the x,y and z axes (into the page, toward north pole and radially outward respectively). now its just a case of projecting w onto the relative axes.
So is it just w= wsin(lambda)j +wcos(lamdba)k as stated in section 6.3? How is writing this down worth 4 marks?
More Edinburgh people! It's only 2 marks. But yeah it's that easy.
  • · Replies 25 ·
