Composition of surjective functions
Korisnik
I'm learning maths myself, but I'm going to university in 2 months. This is my first try at proving anything.
Prove that the composition of surjective functions is also a surjection.
A definition of surjective function:
If f:S_1\rightarrow S_2 is a surjection:
\forall y\in S_2\exists x\in S_1:y=f(x).
A definition of composition of functions:
If f:S_1\rightarrow S_2 and g:S_2\rightarrow S_3 are functions, then h:S_1\rightarrow S_3 is the composition of functions f and g:
g\circ f(x)=g[f(x)]=g(y)=z.
I've read some of the texts that talk about proofs, and all of them made sense to me, for example the proving of an irrational number and square roots, but I can't say if this proof is "enough".
If f:S_1\rightarrow S_2 and g:S_2\rightarrow S_3 are surjections by definitions:
\forall y\in S_2\exists x\in S_1:y=f(x)\ \ \ \ (1)
\forall z\in S_3\exists y\in S_2:z=g(y)\ \ \ \ (2),
composition of these two functions g\circ f(x) is also a surjection.
We have to prove:
\forall z\in S_3\exists x\in S_1:z=g\circ f(x).
Let z\in S_3, then there is a particular y\in S_2 such that z=g(y) by the (2) axiom and there is a particular x\in S_1 such that y=f(x) by the (1) axiom. It follows that z=g(y)=g[f(x)]=g\circ f(x) which is by the definition, the composite of functions f and g. This means that for all z we've found a particular x for which the statement is true.
Your proof is fine. I noticed one typo: you wrote ##g : S_1 \rightarrow S_2## when it should be ##g : S_2 \rightarrow S_3##. Also, a minor notational observation: the "mapsto" arrow ##\mapsto## is usually used to indicate how elements are mapped, whereas the "rightarrow" arrow ##\rightarrow## is used for the domain and codomain. Example: the function ##f : \mathbb{R} \rightarrow \mathbb{R}## defined by ##x \mapsto x^2##.
By the way, a good practice to help understand a theorem and its proof is to consider what happens if one of the hypotheses is excluded. Can you come up with examples where only one of ##f## or ##g## is a surjection, and ##g \circ f## fails to be a surjection?
Yes, it was a typo indeed, I kept checking, but this scheme-text (3 parts of asking a homework question) kept popping up so I had to delete it.
I've been told to use the "mapsto" when I used "rightarrow"... even though in the book the "rightarrow" is used. Sorry for that.
By the way, a good practice to help understand a theorem and its proof is to consider what happens if one of the hypotheses is excluded. Can you come up with examples where only one of f or g is a surjection, and g\circ f fails to be a surjection?
Isn't a surjection just a matter of defining sets (domain and co-domain), therefore if a function is defined otherwise, I can claim it's (not) a surjection.
(For example, f(x)=x^2, f:\mathbb{R}\rightarrow\mathbb{R^+} is a surjection, whereas if it was defined as f:\mathbb{R}\rightarrow\mathbb{R} it wouldn't be a surjection.)
Example where f and g are not both surjections:
f(x)=2x\space (1)\\g(y)=y^2\space (2)\\g\circ f(x)=4x^2\space (3)
(1) is a surjective, (2) isn't, and so (3) isn't.
It's not a big deal, if your instructor prefers "mapsto" then go ahead and use that.
Yes, this is all correct.
Right, assuming the codomain of ##g## is something larger than ##\mathbb{R}^+## (for example ##\mathbb{R}##).
How about if ##g## is a surjection but ##f## is not? Do you see what goes wrong in that case?
jbunniii said:
[...] How about if ##g## is a surjection but ##f## is not? Do you see what goes wrong in that case?
I hope so, I'll try to illustrate.
Using the same functions but switching names (assuming: f:\mathbb{R}\rightarrow \mathbb{R} for f(x)=x^2 and g:\mathbb{R}\rightarrow\mathbb{R} for g(y)=2y).
g\circ f(x)=2x^2, which again isn't a surjection (if it was, it would be g\circ f:\mathbb{R}\rightarrow\mathbb{R}), because in reality:
g\circ f(x)=g\circ f(\mathbb{R})=g[f(\mathbb{R})]=g(\mathbb{R^+})=\mathbb{R^+}\Rightarrow g\circ f:\mathbb{R}\rightarrow\mathbb{R^+}.
Therefore condition (g\circ f:\mathbb{R}\rightarrow\mathbb{R}) isn't fulfilled, and it's not a surjection.
If that's what You meant.
Yes, that's what I meant, although be careful about the statement that ##g\circ f:\mathbb{R}\rightarrow\mathbb{R^+}##. The set to the right of the ##\rightarrow## is the codomain, not necessarily the image. Indeed, we must have ##g\circ f:\mathbb{R}\rightarrow\mathbb{R}## because the codomain of ##g \circ f## is the same as the codomain of ##g## (by definition). However, ##g \circ f## is not a surjection because ##g(f(\mathbb{R})) = \mathbb{R^+}##, which is a strict subset of the codomain ##\mathbb{R}##.
Yes but I wrote "in reality"... hahah. It was a quazi-conclusion about "real" codomain to make it easier to compare what has to be compared. Thanks for everything!
Yes, I understood what you meant. Just wanted to point out that the "right" way to say it is that ##g(f(\mathbb{R})) = \mathbb{R^+}##, not ##g\circ f:\mathbb{R}\rightarrow\mathbb{R^+}##. Mathematicians (probably including the ones grading your homework once you get to your university) are pretty pedantic about notation. :biggrin:
