Compressed Air Car: Feasibility & Analysis
The discussion focuses on the feasibility of using compressed air to power a car, with the user detailing their project methodology, including deriving equations for driving force and calculating required inlet pressures for a reciprocating air motor. Key questions arise about the possibility of modifying a conventional car engine for this purpose, with responses indicating that extensive modifications would be necessary, particularly regarding the valves and camshaft. It is suggested that using a modified two-stroke diesel engine or existing air motors might be more practical than adapting a traditional engine. The user is encouraged to explore resources like "MiniCAT" for further information on compressed air motoring. Overall, the conversation emphasizes the complexities and challenges of converting conventional engines for compressed air use.
nishat
hi there,
i am studying the feasibility of compressed air to power a car as my final year project and i need some guidance.
How i proceeded:
(1) I derived equations for the driving force and consequently for the road-load power of a car, with speed as the variable.
(2) I worked backwards using data about power losses in engine and in car transmission which i assumed to be almost constant. I tabulated the indicated power and indicated mean effective pressure inside the cylinder required at different speed
(3) I then calculated the inlet pressures of compressed air required at different cut-off ratio and at different speed if the engine was to operate as a reciprocating piston air motor with 4 cyl in line such that when two pistons are doing the power stroke, the other two are performing the exhaust stroke.
My questions are :
1.Can a conventional car engine be used as a reciprocating air motor, that is, with the same piston-cylinder assembly, piston rings, connecting rod, crankshaft?
2.What about the valves?
Oh no not again.
We already have a compressed air car thread, although little out of it may be useful to you since it seemed to verge on perpetual motion at times.
https://www.physicsforums.com/showthread.php?t=310462
To answer what I can.
1. Yes with extensive modifications. May not be worth it to you, since the cost of modifying is probably more expensive than an off the shelf air motor.
2. Complete rework on the valves/camshaft. A regular internal combustion engine has valve strokes that are very different from an air motor. You have to get rid of the compression phase.
Your best bet may be to use a 2 stroke diesel modified for bash valves. These have been used for steam powered setups, but should work just fine with compressed air. Or alternatively you could use existing air motors and avoid the hassle entirely.
One of these on each wheel and I think you would be in buisness.
http://www.grainger.com/Grainger/items/5KB10?Pid=search
Hi,
I understand that it's boring to discuss the same topic, but, thanks for the reply. (i really needed help)
Luckily I am not building one; but i need to discuss these in details in my project.
1.When you mentioned 'extensive modifications', apart from lighter materials and flat piston design etc , can we use the same design of crankshaft, connecting rod. (I could not get much info about reciprocating piston air motor.)
2. If I am right, the valve strokes depend on the profile of the cams. Is it possible to replace the existing cams by new cams designed to allow the valve to open for inlet stroke until cut-off, close for power stroke (expansion), and open again for exhaust stroke? In addition, two pistons will perform the same stroke simultaneously (ex power stroke) while the other two will perform the exhaust stroke.
i have to read more about bash valves.
I read about air motors at wheels, but, do not know much about it. I calculated the input pressure of air to provide the same power output based on the existing I.C engine.
nishat,
Google "MiniCAT" for all the information you would care for about compressed air motoring.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
