Compression of an object and its length.
  • Thread starter Thread starter windy miller
    Compression Length
The discussion centers on the claim that shorter foam rollers can withstand greater weight and deform less than longer ones. Participants argue that the stress on an object is calculated by force divided by area, suggesting that a smaller roller should perform worse, not better. It is noted that the distribution of force applies differently to rigid surfaces compared to foam rollers, which are designed to compress. The consensus is that the length of the roller does not significantly affect its performance if both are made from the same material. Overall, the claims about the superiority of shorter rollers lack a solid scientific basis.
windy miller
I have heard a claim that looks a little odd to me and I am hoping that someone can help.
In the gym there are foam rollers people use, some of them are 36 inches long and some are 16 inches. The claim is that the shorter ones can withstand greater weight than longer ones and will have less tendency to become deformed than the longer ones. If i recall the stress on an object is the force divided by the area, so if anything a smaller roller should do worse not better but intuitively i feel it shouldn't make any difference , the section of the roller the person is applying pressure to is basically the same.
Can anyone help in sorting this matter out.
I agree w/ your analysis. The idea that a larger surface spreads out an applied force only applies to rigid surfaces and that's not the case for gym mats. Don't see why an extra mile or two of material off to the side would make the slightest difference to the part that pressure is applied to in this case. This assume, of course, that they are made of exactly the same material.
Likes windy miller and CWatters
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 29 ·
