Compressor vs Condenser - what's the difference?
1 reply · 40K views · last reply
wavingerwin
I read about refrigerators and often a fridge has two components:
1. compressor
2. condenser
Diagram of a typical single-stage vapor compression refrigeration cycle showing compressor, condenser, expansion valve and evaporator with a fan, with labelled vapor, liquid and liquid plus vapor flows and cold and warm air arrows.
The compressor compresses the vapor - what does it actually do? does it increase the temperature of the vapor?
The condenser condenses the vapor into liquid
and then the liquid is expanded, resulting liquid and vapor in low pressure providing coolness
If you compresses something, don't you just make it denser hence it has more pressure?
How can you compress something without making it denser?
Thank you
Yes, the compressor compresses, resulting in higher temperature and density/pressure. You got that image from wikipedia - the next image down on that page gives you detail of what happens in each process.
