Compressor work and Thermodynamics
The discussion focuses on evaluating compressor work using the heat capacity at constant pressure, denoted as Cp, despite pressure variations between the inlet and outlet sides. It is established that for an ideal gas, the enthalpy change (ΔH) can be calculated using the formula ΔH = CpΔT, which holds true regardless of pressure differences. The conversation emphasizes that Cp is a state function, and its value may differ between initial and final states, necessitating integration of dH = CpdT when heat capacity varies with temperature.
  • Understanding of thermodynamic principles, specifically enthalpy and heat capacity.
  • Familiarity with ideal gas behavior and state functions.
  • Knowledge of integration techniques in thermodynamics.
  • Basic concepts of compressor operation and thermodynamic cycles.
  • Study the derivation of the enthalpy change formula ΔH = CpΔT for ideal gases.
  • Learn about the integration of heat capacity functions with temperature variations.
  • Explore the implications of varying heat capacities on compressor efficiency.
  • Investigate real-world applications of thermodynamic principles in compressor design.
Engineers, thermodynamics students, and professionals involved in compressor design and analysis will benefit from this discussion, particularly those seeking to understand the relationship between heat capacity and compressor work in varying pressure conditions.
rishi kush
how can we use Cp.dT to evaluate compressor work even when one side (inlet side) is having different pressure than other side (outlet side). Cp should be used for constant pressure!
For a constant pressure process, the amount of heat Q is equal to ##C_p\Delta T##. Otherwise, Q is not equal to that. But, for an ideal gas, irrespective of the pressure variation, the enthalpy change ##\Delta H## is always equal to ##C_p\Delta T##. This is because, in thermodynamics, ##C_p## is defined in terms of the enthalpy change rather than in terms of the amount of heat transferred. The two definitions match only if the pressure is constant.
since Cp is a state function , its value should be different for initial and final states of a process? and which value should we have to consider?
If you have a heat capacity which varies with temperature, you integrate ##dH=C_pdT## between the initial and final temperatures to get the enthalpy change.
  • · Replies 20 ·
  • · Replies 33 ·
