Compton Scattering: Determining the Energy of a Scattered Gamma Ray
The discussion focuses on calculating the energy of a scattered gamma ray using the Compton scattering formula. The relevant equation is E(gamma prime) = E(gamma) / (1 + (E(gamma) / (mc^2))(1 - cos(theta))). Participants confirm that the energy of the gamma ray, 0.662 MeV, should be retained in MeV rather than converted to joules, as this simplifies the calculations. The mass of the electron should also be expressed in MeV/c² to maintain dimensional consistency.
  • Understanding of Compton scattering principles
  • Familiarity with the equation E(gamma prime) = E(gamma) / (1 + (E(gamma) / (mc^2))(1 - cos(theta)))
  • Knowledge of energy units in MeV and their relationship to mass in MeV/c²
  • Basic trigonometry for calculating angles in scattering problems
  • Study the derivation and applications of the Compton scattering formula
  • Learn about the conversion between MeV and joules for energy calculations
  • Explore the implications of scattering angles on energy distribution
  • Investigate the role of photons in particle physics and their interactions with matter
Students in physics, particularly those studying quantum mechanics and particle interactions, as well as educators looking for clear examples of Compton scattering calculations.
ChrisWM
A 0.662 MeV gamma ray Compton scatters from an electron at an angle of 60°. What is the energy of the scattered gamma ray? (Gamma rays are photons and are treated identically to x-rays in the analysis of Compton scattering.)
E(gamma prime)= E(gamma)/(1+(E(gamma)/(mc^2)(1-cos(theta))) ?
I'm unsure of how to proceed here. Would I use the equation
Also, do I keep the .662 Mev as is or do I convert to joules?
ChrisWM said:
Homework Statement:: A 0.662 MeV gamma ray Compton scatters from an electron at an angle of 60°. What is the energy of the scattered gamma ray? (Gamma rays are photons and are treated identically to x-rays in the analysis of Compton scattering.)
Relevant Equations:: E(gamma prime)= E(gamma)/(1+(E(gamma)/(mc^2)(1-cos(theta))) ?
If you already have an equation for the change in energy, then why not use it?
Definitely use ##MeV##. Note that ##\frac{E}{mc^2}## is dimensionless. If you have ##E## in ##MeV##, then you need ##m## in ##MeV/c^2##. Which is much simpler than converting everything to SI units in this case.
  • · Replies 18 ·
