Compute flux through rectangular area
The discussion focuses on calculating the magnetic flux through a rectangular area near a current-carrying wire. The relevant equations include the flux formula Φ = ∫B·dA and the magnetic field B = (μI)/(2πr). Participants clarify the setup for the integral, confirming that using rectangular coordinates is appropriate. The correct integral setup is identified as (μI)/(2π) ∫_0^b ∫_d^(d+a) (1/r) dr dy, which leads to a solution involving natural logarithms. The conversation emphasizes the importance of proper coordinate systems in solving the problem.
EV33
There is an aXb rectangular area in the same plane as a wire with current I. The wire is parallel to side b, and a distance d away. Compute the flux through the rectangular area.
\Phi=\intB*dA
B=(\muI)/(2\pir)
cylindrical coordinates... rdrd\thetadz
(\muI)/(2\pi)\int\int\int(1/r)(rdrd\thetadz)
dr is from d to d+a
d\theta is from 0 to 2\pi
dz is from 0 to b
The solution to this ends up having natural logs in it, and to do that I would have to drop r, but I don't feel like that is right. Could someone please help point me in the right direction on setting up this integral.
Thank you.
I am not sure why some things look like subscripts or exponents so just a warning there are no exponents are subscripts lol
I think I see why now. I should be using rectangular coordinates huh?
I don't know what I was thinking... I must have been thinking partially of amperes law
(\muI)/(2\pi)\int\int(1/r) dr dy
dr from d to d+a
dy from 0 to b
would this be the correct set up?
Yes, that's the correct setup. Your solution should have a natural log in it.
dr from d to d+a
dy from 0 to b
\frac{ \mu I }{2\pi} \int_0^b \int_d^{d+a} \frac{1}{r} dr dy
Code:
Hope that helps, though it's nothing to do with the actual question.
