Computer Engineering or Computer Science?
Many Computer Engineering (CE) hardware jobs are increasingly outsourced, leading to concerns about job availability in this field. Despite this trend, there are ample programming opportunities available, and individuals with a CE degree can successfully pursue programming roles, including high-level coding in languages like Java. Relevant coursework is essential for securing these positions, and candidates are often evaluated on their communication skills, as clear writing can influence hiring decisions. Resources such as the Bureau of Labor Statistics provide valuable insights into employment projections and salary expectations for both CE and programming careers.
Sentience
I have heard that many of the Computer Engineering hardware jobs are mostly outsourced these days. Is this true? I'm kind of frustrated because I don't mind programming but I like learning about hardware too.
But, I know there are tons of programming jobs. Can someone with a CE degree still get a programming job doing high level code like Java or is that a job for a CS degree?
Welcome to the PF. One of the cool features here, is that once you start a thread, there is a section down at the bottom of the thread that shows Related Threads. There appear to be a number of them! Wow. The first one has 28 posts, so hopefully it will help you out some. Here's the direct link:
https://www.physicsforums.com/showthread.php?t=179816
Sentience, I've interviewed a number of people over the last ten years for Java development positions. If you've taken the required courses, you can get work as a programmer. My own degree isn't in computer programming and I've done fine.
After reading the link that berkeman posted, there was one good insight to getting a job that I definitely agree with - netspeak, sloppy writing, etc. do get noticed on resumes and correspondence. If I have a choice between two identical developers, guess who I'm going to choose? BTW, that advice is for anyone else who may be reading this - your writing is fine.
Obligatory BLS links:
http://www.bls.gov/oco/ocos266.htm"
http://www.bls.gov/oco/ocos267.htm"
http://www.bls.gov/oco/ocos110.htm"
http://www.bls.gov/oco/ocos042.htm"
These pages contain the official US government answers to your questions. Make sure you check out the employment projections, and where they have it, starting salary. See also the related occupations.
Hi all, Hope you are doing well. I'm a current grad student in applied geophysics and will finish my PhD in about 2 years (previously did a HBSc in Physics, did research in exp. quantum optics). I chose my current field because of its practicality and its clear connection to industry, not out of passion (a clear mistake). I notice that a lot of people (colleagues) switch to different subfields of physics once they graduate and enter post docs. But 95% of these cases fall into either of...
  • · Replies 18 ·
