Computer Keyboard Hacks to Fix UI Problems
  • Thread starter Thread starter berkeman
    Computer Keyboard
16 replies · 3K views
Admin
TL;DR
What hacks have you used to bypass UI problems? Are there better solutions?
With Win7 and Win10 laptops, the UI has some serious issues, IMO. I've had several work and personal laptops with super sensitive touchpads, and lately the Num Lock key has proved problematic.
On my older laptops, I was able to use the Control Panel to disable the touchpad so that it would not send me off into oblivion when my palm brushed it, but with the latest Windows operating systems that does not seem to be an option. I can turn down the touchpad sensitivity, but even at the minimum setting, I still end up vectoring off to the corners of my document and deleting random text (which is really time consuming to recover from) if my palm brushes the dang touchpad.
And having the Num Lock key right next to the Backspace key seems like a poor keyboard design to me, since a slight overstep on Backspace can disable the Num Lock, which then results in you vectoring off into hyperspace the next time you try to type a number, and can also result in random deletions of text in a document that you are working on.
At least on my HP laptop I can mouse down to the status bar to see if my NumLock is still turned on, but on my wife's work laptop (she is working from home) we have not been able to find such a status indicator.
So, I've "engineered" some workaround physical hacks for now (ESD pads over the touchpads and keyboard guards over the problematic NumLock key). But there has to be a better way. A coworker suggests that there is a Bios disable for the touchpad thing, but I haven't tried that path yet...
I can use the touchpad switch under W10 on Lenovo. I haven't figured out how deep into the system I can get with AutoHotKey, but I used it on an older machine to replace a broken 'e'-key, and now I still use it to disable caps lock, and the overwrite function of 'insert'.
Edit: Of course you can always use the engineers' solution:
Just make sure to cover the touchpad with some paper first.
Edit Edit: And now that you have asked, I set the Num block on always active.
I have a newish Dell laptop running Win 10. I have a wireless mouse for it and have no use for the touch pad. The Settings app can be used to turn off the touchpad. Look under Devices --> Touchpad.
Mine is a newish HP laptop running Win 10 also. In the Touchpad Settings, all I can do is turn it down to Low Sensitivity. I haven't found an On/Off switch yet. Does your Touchpad Settings window look like this?
How did you do that?
I redirected NumLock to Space via AutoHotKey
SetNumLockState, On
Return
NumLock::
Space:
Return
For the really rare case that I want to use it as arrows, I could simply pause the script.
Regarding the touchpad settings, here's what are shown in Settings for my Dell Vostro laptop. Since your HP laptop doesn't seem to show the same things, maybe there's something you can jigger in Control Panel.
But does yours have a "ya/nein" switch?
No, it has only a strictly positive sensitivity switch: low, middle, high, highest. However, it came with a separate machine software to handle settings like energy consumption, mouse, camera etc. Unfortunately it only links to the MS setup page under the point touchpad. But I have a function key to switch it off.
What's under Related settings. . . this ?
Enable or Disable Double Tap to Enable or Disable Touchpad in Windows | Tutorials
Also, check out the Related Tutorials. . .
PS:
I use a desktop, so I don't even have a setting for a Touchpad, but I am a
member of that Forum, and https://www.tenforums.com/members/brink.html seems to know his stuff. . . . :smile:Oh, one more thing, my Wife has an HP laptop, but I'm not allowed close to it,
and I do MEAN close !. . :oops: . :DD
That leads to settings where I can deactivate the touchpad. Not as convenient as a switch at the top level, but it should work.
PS:
and I do MEAN CLOSE !. . :oops: . :DD
Good thought, but it looks like the Advanced settings under my Touchpad settings takes me to my mouse settings. (Dang, I'd be cursing out HP at this point, but I worked for them for a number of years, so will resist that urge...)
Last resort: Open up the case and unplug the d**n thing!
  • Wow
