Computer problem : need understanding
  • Thread starter Thread starter JPC
    Computer
A user experienced a computer issue where the system displayed an 'NTLDR missing' error after adding components due to insufficient power supply connections. Initially suspecting a hard drive failure or virus, the user found that disconnecting a secondary hard drive resolved the issue. The discussion highlighted potential causes for the problem, including a virus, overheating due to dust, or incorrect drive configurations. It was suggested that the BIOS may have reset due to a low CMOS battery, which could explain the sudden changes in settings. The user successfully reconfigured the BIOS and resolved the immediate issue but remains curious about the underlying cause of the reset.
JPC
Computer problem : need understanding !
hey
i have a computer with lots of componements like big graphic cards, Tv card, ect
my alimentation didnt have enough sub plugs to plug all my componements so i had to use a thing to dooble 1
since now, no problems
but suddenly , pc bugs, when i restart , just after the Motherboard display, says 'NTLDR' missing
there i was like : my Main hard disc destroyed itself, or really nasty virus that modified my XP boot program
then, i tried unplugging one of my other hard discs
rebooted , and worked
why suddenly, i cannot have another componment, and before i could
now i probs have to buy new alimentation
(sorry if i don't have the right vocab, but i have all the PC vocab in french so ..)
Computer science news on Phys.org
I'm no expert, but in my old computer repair class ntldr error usually was before reloading the operating system.
Restart and enter your computers BIOS, check the hard drive boot order. If you added a hard drive, this may have changed. Regardless, try chaning the hard drive ordering and see what works.
i have now tested some things and i understand some things
in a way that i don't know
possibly :
- bad virus, trojan, ect
- dust in pc which heated, and got the motherboard not enough power
the motherboard reseted itself
and it confused my IDE disk , and my SATA disk
and so when i boot, it tried to boot with my secondary disk (with no windows on it)
that would explain why
when i disconect my secondary disc , everything works
but now, i am wondering about the cause
what do u think :
- other ?
Possibly you have the master and slave drives mixed up.
But regardless, the key here for you is to make small steps in locating the problem. Set aside your theories for the moment and let's go to empirical evidence. Remove components until you have it working again, then install them one-by-one as per instructions until you repeat the error, then give us the error and the steps that led up to it.
but i have already have it working again
i saw all my BIOS had been reseted
i just reconfigured it all, and now , its working again
what i am interested in is : why my BIOS reseted suddenly ?
It's a mystery JPC.
Glitches are built into every motherboard... :smile:
Aquafire
A likely cause of the BIOS spontaneously resetting itself to it's default settings is low power in the CMOS battery on the mobo. If it happens again try putting in a new battery.
ok noted, thanks
  • · Replies 25 ·
14K
