Computing semimajor axis from ecentricity and period
3 replies · 4K views
Gary Roach
Compute the semimajor axes "a" of Halley's Comet.
Given:
orbital eccentricity e = 0.9673
period P =76 days (2.39674E9 seconds)
Gravitational Constant G = 6.67428E-11
solar mass M = 1.9891E30 Kg.
Also used in equations are:
L = angular momentum of center of mass
[tex]\mu[/tex] = reduced mass
r = distance from focus to comet mass
b= semiminor axis of elipse.
I used:
[tex] \frac{dA}{dt} = \frac{L}{2\mu} = \frac{A}{P}[/tex]
[tex]A=\pi a b[/tex]
[tex]b^2=a^2(1-e^2)[/tex]
[tex]L=\mu\sqrt{GMa(1-e^2)}[/tex] from text
[tex]L=\frac{2\pi \mu a^2 (1-e^2)}{P} = \mu \sqrt{GMa(1-e^2}[/tex]
[tex]a = \sqrt[1/3]{\frac{GMP^2}{4\pi^2 (1-e^2)}}[/tex]
Unfortunately "a" turns out to be 6.6964E12 meters = 44.76 AU .
Since the data is for Halley's Comet, a should be 17.8 AU
Where did I go wrong
Looks like you've got an extra factor of [itex](1-\epsilon^2)^{-1/3}[/itex] in your final result...I think the [itex]1-\epsilon^2[/itex] you get from [itex]b^2=a^2(1-\epsilon^2)[/itex] should cancel with the [itex]1-\epsilon^2[/itex] you get from [itex]L=\mu\sqrt{GMa(1-\epsilon^2)}[/itex] when you substitute everything in properly...
The eccentricity is not involved in Kepler's third law, suggesting you made an error. And you did. What is the area of an ellipse?
OK Stupid error. Its not the first time. After getting that straightened out, on rereading the problem I wonder if it is possible to solve for the semimajor axis "a" with only the eccentricity, period and gravitational constant.(ie no solar mass) . Any comments?
Thanks for your help
Gary
