Concept to extract heat energy from objects
5 replies · 3K views
Dray1480
I was just thinking about absolute zero temprature roughly -250 c degress
Lets say an object has a room temprature of 20 degrees celsius
Doesnt it mean i has a lot of thermal emegy
So i used the equation
H= Cp x M x ΔT
H = Heat energy (in Joules)
m = mass (in kilograms)
delta T = change in temperature (in degrees Celsius)
Cp = Specific heat (in J/kg x degrees C)
If the material is glass with mass of 1 kg it would have 263550 joules of energy??
Im just a as student I am completely wrong just say so
Q = M . C . dt (How do you get the triangle symbol) is how I write the equation, but they are the same thing.
You should work in kelvin really, but a change of 1 in either unit is equal so that's no big deal here.
Anyway, 0k is ~-273 degrees celsius.
What your equation says, is that it takes 263550 joules of energy to heat 1 kg of glass from 0k to 293k.
p.s I haven't actually checked your numbers, but assuming they work out.
yes but the object is already heated to room temperature from its surroundings
Yes, your object at room temperature has 263550 Joules more heat energy per kilogram than the same object at absolute 0. But so what? You titled this "Concept to extract heat energy from objects" and you said nothing about extracting the energy
If what you're looking for is an efficient way to 'extract' that energy from an object, you simply need to place the object in a large temperature differential with good conductance.
It's basically a fridge.
Specific Heat capacity of glass is 840 Joules/kg/k so yes 1kg at room temperature 293K contains about 250,000 Joules.
It's not too hard to extract some of it. As lntz said you could put it in a fridge or use another type of heat pump.
Heat pumps for houses work by extracting heat from the outside air or ground and moving it indoors. They can even operate when the outside temperature is below freezing. The problem is that even the best heat pumps need some energy to run. The COP (Coefficient of Performance) for a typical heat pump for houses is typically in the range 2 to 6. In other words they use 1 unit of energy to move between 2 and 6 units of energy from outside to inside.
