Conceptual difficulty with FP Resonator
H_man
If we have a resonator composed of 2 partially transmitting mirrors/grids and we excite the resonator from one end, say the left side then on the right we expect to get the characterstic transmission comb and on the left the inverse (1-Transmission) reflection curve.
Whats giving me a headache is this... shouldn't we see the characteristic transmission curve at both ends of the resonator as the frequency that is being built up is dependent upon the length of the resonator not its orientation in space... it shouldn't matter to the resonant wave which direction its going in.
So.. at the left side we'd see reflection curve + half transmission curve and at the right end just half the transmission curve.
Put perhaps slightly more clearly. If we have a 1mW laser going in from the left we are going to get 1mW coming out from the right if the frequency is tuned correctly, but I don't see why we shoudn't get 0.5mW from each end leaving the resonator??
:confused:
H_man said:
If we have a 1mW laser going in from the left we are going to get 1mW coming out from the right if the frequency is tuned correctly, but I don't see why we shoudn't get 0.5mW from each end leaving the resonator??:confused:
You should, and this is what happens if you excite the cavity with a pulse, turn off the laser and look at the decay. In this case the two ends are equivalent.
However, as long as you are pumping the cavity with a laser the reflected signal will be composed to two components, the signal that was reflected without entering the cavity +the signal "leaking" out of the the end. As you long as you have a good cavity these two signal will have a extremely well defined phase relationship, meaning they will superimpose in such a way as to cause cancellations etc.
