Conceptual question about momentum, impulse, and average force.
In the discussion regarding momentum, impulse, and average force, two cars with different masses (Car A: 1400 kg, Car B: 1900 kg) accelerate to the same speed in the same time. Car B experiences a greater change in momentum due to its higher mass, as momentum is calculated using the formula P = mv. However, both cars experience the same impulse, as impulse is defined by the equation Impulse = F(change in T), indicating that the net average force acting on both cars is equal during the acceleration period.
  • Understanding of momentum (P = mv)
  • Knowledge of impulse (Impulse = F(change in T))
  • Familiarity with Newton's Second Law of Motion
  • Basic principles of kinematics and acceleration
  • Study Newton's Second Law of Motion in detail
  • Learn about the relationship between force, mass, and acceleration
  • Explore the concept of impulse and its applications in physics
  • Review problems involving momentum and impulse for practical understanding
Students preparing for physics exams, educators teaching concepts of momentum and impulse, and anyone seeking to deepen their understanding of classical mechanics.
matthayzon89
In a performance test two cars take the same time to accelerate from rest up to the same speed. Car A has a mass of 1400 kg, and car B has a a mass of 1900 kg. During the rest, which car:
a)Has the greatest change in momentum?
b)Experiences the greatest impulse?
c)Is acted upon by the greatest net average force?
P= mv
Impulse= F(change in T)
a) I think that car B has a greater change in momentum because momentum is the product of the velocity and mass, and car B has a greater mass which means the difference or CHANGE will be greater as well.
b) I think the impulse will be the SAME for both cars because the problem states that it takes both cars the SAME time to accelerate and reach the same speed. Which means their force is the same. The fact that both cars have different masses does NOT play a role in the impulse. The fact that one car is heavier just means that the CAR will have to work harder to get the SAME acceleration as the lighter car.
c) Both forces are the same I believe due to my explanation on part (b).
part a is correct,but parts b and c are not. What is the equation for impulse in part b? The answer to part c should readily follow.
Why is my logic incorrect? Why is your logic correct? Can you please explain? I have a test coming up and I am trying to grasp some conceptual questions:)
You correctly answered part a by noting the definition of momentum. Now you need to note the definition of impulse, or better yet, write down Newton's 2nd law and examine it's concept. Also, if the heavier car has to work harder to achieve that acceleration and speed in the same time, this may help in part c as well.
  • · Replies 17 ·
  • · Replies 17 ·
