Why Does Water Take Longer to Cool Than Air in a Refrigerator?
Water takes longer to cool than air in a refrigerator due to its higher specific heat capacity, meaning it requires more energy to change temperature. The discussion highlights that water, being a liquid, has different thermal properties compared to air, a gas, which allows air molecules to dissipate energy more rapidly. The refrigerator's role is questioned, as it seems redundant if both substances start at the same temperature. Clarification is sought regarding the setup, particularly how air would be contained to prevent it from mixing with the cooler air in the fridge. Overall, the cooling dynamics between liquids and gases are central to understanding this phenomenon.
bmb2009
[/B]
Why does it take longer to cool water in a refrigerator than it takes to cool air, assuming that the inside of the refrigerator is initially at the same temperature as the room it is in?
Quite frankly I don't even know if my intuition for the problem is correct (that wording is verbatim of the assignment sheet). My thought is that the water is a liquid and air is a gas so the gas molecules are bumping into the walls and each other dissipating energy faster than the water making the water cool slower. But I don't see the point of the "refrigerator" in this problem... namely... if the inside of the refrigerator is the same temp as the air in the room, it's just a box.. any help?
Thanks![/B]
I guess it's kindof a poorly worded question, ambiguous, and I would assume it's trying to ask:
"If you put a cup, of negligible thickness(say plastic), of water in a frig, and a cup of air in same frig (and somehow kept the air in the cup, e.g., sealed the cup with cellophane), why does it... [...continued as above]?"
I assume they are sealing the air in with cellophane or it would diffuse out into the cold frig air and come to the frig temp fairly quickly.
  • · Replies 28 ·
  • · Replies 42 ·
11K
