Will Your Breath Condense on a Cold Winter's Day? A Homework Challenge
The discussion revolves around a physics homework problem that examines whether breath will condense on a cold winter's day. The breath temperature is 30°C with a dew point of 28°C, while the ambient air is at –10°C with a dew point of –11°C. Calculations reveal that the relative humidity of the breath is 113%, while the air's relative humidity is 108%. Despite both being over 100%, the problem requires further analysis of the mixing of these two air streams to determine if condensation occurs.
  • Understanding of thermodynamics, specifically vapor pressure and relative humidity
  • Familiarity with the equations for calculating relative humidity and vapor pressure
  • Knowledge of psychrometric principles and tables
  • Basic skills in algebra and unit conversions
  • Learn how to use psychrometric tables for air-water vapor mixtures
  • Study the concept of enthalpy in thermodynamic systems
  • Explore the effects of temperature and pressure on vapor pressure
  • Investigate the principles of condensation and phase changes in gases
Students studying thermodynamics, physics educators, and anyone interested in understanding the behavior of gases and condensation in varying temperatures.
Raptor112
On a winter day, suppose your breath has a temperature of 30°C and a dew point of 28°C,and it mixes with the ambient air of temperature –10°C and a dew point of –11°C. Will you see your breath? Assume you are at sea level, and that your breath and the environment mix in proportions of 2 parts (by mass) breath to 1 part (by mass)
environment. Show all your working.
##\frac{p_1}{p_2} = e ^{\frac{L}{R_s}(\frac{1}{t_2}- \frac{1}{t_1})}##
## Relative Humidity = \frac{actual vapour pressure}{saturated vapour pressure} *100##
Found the relative humidity of the breath and air by using, for air:
##t_1 = -10, t_2 = -11##
and for breath
##t_1 = 30, t_2 = 28##
which gives
Relative humidity of air =114%
Relative humidity of breath= 108%
using ##L =2.5 *10^6 Jkg^-1##
##R_s = 461 J K^-1 kg^-1##
Hello Raptor,
Ineresting: in both cases ##t_1>t_2## yet one of the two is over 100% and the other is below ?
Willl you see your breath? was the exercise question, so you till have some steps to take, right ?
What kind of assistance do you need, at what point ?
In both cases the humidity is over 100%.
Assuming my humidity calculation is correct, not sure how to proceed from there? How does the relative humidity of both air and breath tell us if the breath will condensate or not?
My mistake... ? Can you show your working ?
(not that I don't trust your calculations -- although I do get a lightly different answer), but I wonder about your relevant equation: I expect the relative humidity to go down as ##t_1## increases...
Breath:
## \frac{actual vapour pressure}{satrated pressure} = exp [\frac{2.5*10^6}{461} (\frac{1}{28+273.15} - \frac{1}{30+273.15)}] *100 = 113##
Air:
## \frac{actual vapour pressure}{satrated pressure} = exp [\frac{2.5*10^6}{461} (\frac{1}{-11+273.15} - \frac{1}{-10+273.15)}] *100 = 108##
This is a problem in combining two masses of air having different temperatures and mass fractions of water into a single equilibrium mixture of uniform temperature and water mass fraction. It is easiest to do this using Psychometric tables and charts for air/water. Are you allowed to use these tables?
Incidentally, the relative humidity of both streams is less than 100% to begin with.
Chet
Raptor112 said:
I am little confused from the above calulations I showed and that wiki says:
"Exhaled air has a relative humidity of 100%"
https://en.wikipedia.org/wiki/Breathing
Well, be that as it may, that's not what your problem statement says. And, since it's a made-up problem, we're not going to let ourselves get bogged down on that, are we?
The equilibrium vapor pressure of water at 28 C is 3780. Pa and the equilibrium vapor pressure of ice at -11C is 237.74 Pa. There is no need to calculate the relative humidity in this problem.
Now, are you allowed to use tables or graphs of the physical properties or air containing water vapor in this assignment, are are you expected to do the calculations from scratch? We are going to have to calculate the enthalpy per unit mass of each of these streams, and also the enthalpy per unit mass of the combined stream.
Chet
As Psychometric tables were not covered, I think this has to be caluclated from scratch.
You're still in good shape. Start doing the work on mixing these two streams as Chet proposes.
Found the mixed air temperature to be 16.67 degrees with pressure of 1911.04 Pa...
Please show us your work. Also, if you did this correctly, what is your conclusion as to whether you see your breath?
  • · Replies 27 ·
  • · Replies 19 ·
18K
10K
