Condensed Matter/Solid State Physics/Materials Science?
In summary, materials science is more focused on engineering and making materials do things, while condensed matter physics is more focused on understanding physical phenomena in condensed phases of matter.
mc0210
54
Hi all,
I was just wandering what exactly the difference is between the three above areas. From what I understand, solid state physics is a branch of condensed matter. However, would materials science background be very helpful for these areas of study? Any insight would be appreciated, thanks!
Condensed matter usually refers to things like superconductivity, ferromagnetism, topological insulators/other topological phases (usually under solid state), liquid crystals, granular fluids, polymers (soft matter), bose-einstein condensates, cold atomic gases, among other topics.
Materials science seems to focus more on studying materials in order to make materials with certain properties like certain structural or electrical properties. An example of active research is ferroelectrics, materials that have a spontaneous electric polarization that can be switched by applying an electric field.
Thanks for the response! I think its applications are really cool, its just my chemistry is decent, definitely not one of my strengths. Is it a whole lot of chemistry? My current physics teacher is in solid state and I am going to ask him about this area as well.
essentially they all tend to look at similar problems, but depending on what you are trying to accomplish each approach has a slightly different tool set. actually, solid sate and condensesd mater are really the same. condensed could be looked at as taking all the lessons from solid state and seeing that they can be applied to a wide range of problems in systems that may or may not be in a perfect solid state. materials science is more of a engineering approach to the problems of how to make a bit of matter do something in particular. so it will more or less come down to do you see your self as a physicist or an engineer?
Well at the moment, I definitely align more with the physics. I was curious because I find this to be an interesting field and my school has an engineering physics degree with this as a focus. Thought it could make an interesting combination.
From my experience, condensed matter physics tends to look at idealized materials (e.g. near perfect single crystals) and fundamental subjects (e.g. quantum phase transitions at very low temperature physics), whereas materials science is more focused on real-world materials (strained polycrystals full of defects) and very applied questions (how do I make this metal stronger?).
Condensed matter and solid state seems to mean more or less the same, but not all condensed matter is solid.
As always there is a big gray zone in between these subjects that can be either, depending on who you ask.
Thanks for the response! It seems pretty clear to me that the two are not as related as I would have thought.
Again, thank you
Hey. I did a bachelors in physics (emphasis in solid state) and am now in a PhD program in materials science and engineering. Maybe I can provide some insight.
Condensed matter physics deals physical phenomena in condensed phases of matter (solid phases, liquid phase, superconducting phase, ferromagnetic phase, etc.). Condensed matter physicists try to explain the physical phenomena using mostly quantum mechanics, statistical mechanics, and E&M. Solid state physics, the largest branch of condensed matter physics, is concerned with physical phenomena and properties of solids. The emphasis of the research conducted in SS/CM physics is to discover and explain new physical phenomena.
Materials science and engineering is the applied SS/CM physics. Knowledge of SS/CM physics is used to study real world material systems, with the emphasis on practical application. In contrast, physicists are more likely to deal with ideal systems to better study the science behind things. People in MSE also learn more about defects, processing, characterization, etc. in hopes of designing or improving material systems.
Basically, Materials Science = Solid State Physics + Solid State Chemistry, but without the theoretical background and focus of either of those. That is, it focuses more on processing, manufacture and characterization of novel materials for real world use than trying to figure out the physico-chemical phenomena of the materials occurring in nature.
Sometimes, materials science may have elements of metallurgy as well, but not always. You are more likely to work with Ellingham diagrams as an MSE major, for example, while a chemist would be looking at something like Latimer or Pourbaix diagram a lot more. The Solid State Physics major would be more concerned with band diagrams in general :) .
1. What is the difference between condensed matter physics, solid state physics, and materials science?
Condensed matter physics is a branch of physics that studies the physical properties of matter in its solid and liquid states. Solid state physics is a subfield of condensed matter physics that focuses specifically on the properties of solid materials. Materials science is a broader field that encompasses both condensed matter and solid state physics, as well as the study of the structure, properties, and applications of all types of materials.
2. What are some common research topics in condensed matter/solid state physics and materials science?
Some common research topics in these fields include studies of electronic, magnetic, and optical properties of materials, as well as research on new materials for energy storage, semiconductors, and nanotechnology.
3. How does condensed matter physics and materials science relate to other fields of science and engineering?
Condensed matter physics and materials science have strong connections to other fields such as chemistry, biology, and engineering. These fields often collaborate on interdisciplinary research to develop new materials and technologies.
4. What are some real-world applications of condensed matter physics and materials science?
The advancements made in these fields have led to numerous real-world applications, such as the development of computer and smartphone technology, medical devices, renewable energy sources, and advanced materials for construction and transportation.
5. What are some current challenges and future directions in condensed matter physics and materials science?
Some current challenges in these fields include understanding and controlling the properties of materials at the nanoscale and developing sustainable and environmentally-friendly materials. Future directions may include the development of materials for quantum computing, improving energy efficiency in electronic devices, and creating new materials for space exploration.
  • STEM Academic Advising
