Conditional Expectation problem
The discussion revolves around finding the conditional expectation E(X|X<Y) where X and Y are independent exponential random variables with rates a and b, respectively. A user presents an integral approach to derive E(X|X<Y) but struggles to find a closed-form solution. Another participant points out the incorrect integration limits and suggests deriving the conditional density f_{X<Y}(x) to solve the problem. They propose a series of questions aimed at guiding the original poster through the necessary steps to arrive at the solution. The conversation emphasizes the importance of understanding the relevant probability regions and applying the bivariate density function correctly.
jamescaan2004
1. I have a problem that I cannot figure out how to solve. I want to find the following:
E(X|X<Y) where X follows exp(a) and Y follows exp(b) (exp is for exponential distribution). Any ideas on how to solve it?
I got E(X|X<Y) = \int_{-∞}^{∞} E(X|X&lt;y)f_{y}(y)dy = \int_{-∞}^{∞} \frac{\int_0^y x f_x(x)dx}{F_y(y)}f_{y}(y)dy = \int_{-∞}^{∞} \frac{-x e^{-ax}|^{0}_{y}-\int_0^y -e^{-ax}dx}{1-e^{-ay}}be^{-by}dy = \int_{-∞}^{∞} \frac{-y e^{-ay} + \frac{1}{a}e^{-ay}-\frac{1}{a}}{1-e^{-ay}}be^{-by}dy
However, I need to find a closed form solution to this problem in terms of rates a and b. Any ideas on how to solve this problem?
Why do you integrate from ##-\infty## to ##+\infty##? These are exponential distributions, and surely you know what the appropriate range should be!
Anyway, start by obtaining the conditional density ##f_{X<Y}(x)## of ##X##, which is given by
f_{X&lt;Y}(x) \Delta x = \Pr ( x &lt; X &lt; x + \Delta x | X &lt; Y)<br /> = \frac{ \Pr(x &lt; X &lt; x + \Delta x \; \&amp; \; X &lt; Y)}{\Pr( X &lt; Y)}
Thank you very much for your response. I have tried it several times for the last couple of days and cannot get anything out of it. Would you please be able to provide any additional insight?
I am going to ask you a series of questions, and you should try very seriously to answer them. If you do, you ought to obtain the answer to your question.
1) What is the formula for the bivariate density function ##f_{X,Y}(x,y)##, and over what ##(x,y)## region does that apply? From now on, let us call that region the "relevant region".
2) What is the sub-region of ##Y > X## in the relevant region? Using the bivariate density, what is ##P(Y > X)##?
3) For very small ##\Delta x > 0##, what is the sub-region of ##x < X < x + \Delta X \; \& \; Y > X## within the relevant region? Using the bivariate density, what is the probability ##P(x < X < x + \Delta x \; \& \; Y > X)##?
4) Using your answers to 2) and 3), what is the conditional density ##f_{Y>X}(x)##? You obtain it from
f_{Y &gt; X}(x) \, \Delta x = P(x &lt; X &lt; x + \Delta x | Y &gt; X) = <br /> \frac{P(x &lt; X &lt; x + \Delta x \: \&amp; \; Y &gt; X)}{P(Y&gt;X)}
in the limit as ##\Delta x \to 0##. In other words,
f_{Y&gt;X}(x) = \lim_{\Delta x \to 0} \frac{P(x &lt; X &lt; x + \Delta x | Y &gt; X)}{\Delta x}
If you do this carefully and step-by-step you will arrive at a surprisingly simple answer. Then getting the conditional expected value is easy.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
