Conditional probablity loaded die problem
  • Thread starter Thread starter raptor1770
    Conditional
The discussion focuses on calculating the probabilities related to rolling a six with a combination of fair and loaded dice. The initial steps involve determining the probability that Fran rolls a six, considering the loaded die has a higher chance of rolling a six. The use of Bayes' theorem is suggested to find the conditional probability that Fran rolls a six given that Ron rolled a six. Participants clarify the calculations for both scenarios where Ron has either the loaded or unloaded die. The final calculations yield a total probability of approximately 0.222 for Fran rolling a six under the given conditions.
raptor1770
This is part of the study guide for an exam and I'm not sure how to start.
Consider three identical-looking dice. Two of the dice are ordinary fair dice (six equally-likely faces, numbered 1,2,...,6), but the third die is "loaded" (the face that ordinarily has a 1 has a 6 instead; that is, the loaded die has two 6's, on opposite faces). Fran and Ron each choose a die at random, and the remaining die is discarded.
Suppose that Fran and Ron roll their dice simultaneously
1. Find the probability that Fran rolls a 6.
4. Find the probability that Fran rolls a 6 if it is known that Ron rolled a 6.
Am I supposed to use Baye's theorem to solve this problem? Thank you for any help.
You have not made an attempt to solve the problem.
Well I'm really at a loss as to where to start but I'll give you what I got so far.
The probability of rolling a six on a normal die is 1/6
on a fixed die it is 1/3
The probability that Fran picked the loaded die is 1/3; the regular die 2/3.
So the total probability of rolling a 6 is probability of 6 on loaded multiplied by chance to pick loaded plus probability of 6 on unloaded die multiplied by chance to pick unloaded.
or
Code:
(1/3*1/3) + (2/3*1/6) = .2222
Let me know if I am on the right track. Thank you.
EDIT: Still working on 4.
looks good. Make sure to remember that there are different ways in which number 4 can happen. this depends on if ron has the loaded die or not.
For question 4 I think the solution is something like this.
Let L = Loaded
U = Unloaded
p = probability
The probability of rolling 6 given 6 is
= \frac{p(6|6) p(6)}{p(6|L) p(L) + p(6|U) p(U)}
This is derived using Baye's theorem. I think the numerator is incorrect because I don't know what the probability of 6 given a roll of 6 is.
if you do the math out for me then I'll guide you. That really doesn't help me troubleshoot your method.
What I would suggest doing is finding the probability of rolling a 6 given that Ron rolled the loaded die, and then find the probability of rolling a 6 if Ron rolled a regular die.
Then there is another step but I think you can get it. Its actually very very similar to question 1.
OK based on your suggestion I calculated the probablity of rolling a 6 based on Ron getting the loaded die and the unloaded die. I think it's right please let me know.
If Ron got the loaded die:
(1/6 * 1) + (1/3 * 0) = 1/6
If Ron got the unloaded die:
(1/6 * 1/2) + (1/3 * 1/2) = 1/4
So from that information I can calculate the total probablity which is:
The probability of rolling a 6 if Ron got the loaded multiplied by the probability of Ron getting a loaded die, plus the probability of rolling a 6 if Ron got the unloaded multiplied by the probability of Ron getting the unloaded or:
(1/6)*(1/3) + (1/4)*(2/3) = .222
Thanks
perfect.
  • · Replies 31 ·
  • · Replies 18 ·
