Conditions for solutions to aZ + b·Z̄ + c = 0
  • Level: Graduate
  • Thread starter PcumP_Ravenclaw
    Doubt
1 reply · 4K views · last reply
PcumP_Ravenclaw
Dear all, can you please help me show why the 2nd scenario below has no solution...
Theorem 3.3.1 Suppose that a and b are not both zero. Then the equation ## aZ + b\bar Z + c = 0 ##
has
a, b and c are complex numbers. Z is the unknown complex number.
(1) a unique solution if and only if ## |a| != |b| ##;
(2) no solution if and only if |a| = |b| and ## b\bar c != c\bar a ##;
(3) a line of solutions if and only if |a| = |b| and ## b\bar c = c\bar a ##.
Answer:
In the equation ## aZ + b\bar Z + c = 0 ##
a,b and c are complex numbers.
for |a| = |b|, say ##a = f + ig##
then |a| = ## \sqrt{f^2 + g^2} ##
negative f and g will be equal to positive because of the square root
so b can be ## f + ig, f - ig, -f + ig, -f -ig, g + if, g - if, -g + if, -g - if ##
if |a| and |b| are equal i.e. when a and b are any of the complex numbers above then there may be repeated solutions for z.
if ##z = z1 + iz2 ## then for two different a and b in the above list z1 will same and z2 will be same.
(2) no solution
if |a| = |b| then ONLY repeated solutions will occur and a and b are only one of the eight complex numbers given, c is any complex number?
what does the condition ## b\bar c != c\bar a## do?(3) line of solutions
(3) what does the condition ## b\bar c = c\bar a## do?
Hey PcumP_Ravenclaw.
The easiest way to do this (since it is a linear problem) is just set a = x + yi, b = d + ei, c = o + pi and Z = q + ri and get the solutions for the real and imaginary parts to equal 0.
If you do this, then it will be easier to answer your own questions.
