kenewbie
- 238
If I simply drop a stone, it takes s seconds to hit the ground. If I throw the stone parallel to the ground, it also takes s seconds to hit the ground, regardless of horizontal momentum.
However, if I throw my frisbee it will be airborne for much longer than it does when I drop it, even if I throw it parallel to the ground. In fact, the harder I throw, the longer it stays in the air.
Why? I would guess that it floats on the air somehow? Or perhaps, when I say that I throw it parallel to the ground, it has just enough upward angle to gain the same amount of lift as gravity is pulling it down, and so they cancel each other until i loose momentum.
But if that is the case, it leaves the question of how the lift is generated. I've read that you get low pressure on the top of the disk due to the rounded rim (rounded upwards) but would not that simply make MORE of the air go ABOVE the disk, and so make it HIGH pressure compared to below?
Enlighten me, please!
k
k
