Confused about some notation used by Griffiths
The discussion centers on the confusion surrounding Griffiths' notation for the expectation values of the x and y components of a 1/2 spin particle. The user correctly derived the x component as ## \left< S_x \right> = \frac \hbar 2 (b^*a+a^*b)##, but Griffiths simplifies it to ## \hbar~Re(ab^*) ##. For the y component, the user found ## \left< S_y \right> = \frac \hbar 2 i (ab^*-a^*b)##, while Griffiths equates this to ## - \hbar~Im(ab^*)##. The confusion arises from the absorption of the factor of 1/2 and the treatment of complex numbers, specifically the relationships between real and imaginary parts.
  • Understanding of quantum mechanics, specifically spin-1/2 particles.
  • Familiarity with complex numbers and their properties.
  • Knowledge of expectation values in quantum mechanics.
  • Ability to manipulate mathematical expressions involving complex conjugates.
  • Review the properties of complex numbers, focusing on real and imaginary parts.
  • Study the derivation of expectation values for quantum states, particularly for spin systems.
  • Learn about Griffiths' notation and its applications in quantum mechanics.
  • Explore the mathematical relationships between complex conjugates and their real/imaginary components.
Students and professionals in quantum mechanics, particularly those studying spin systems and complex number manipulation, will benefit from this discussion.
kmm
I worked out the expectation values of the components of a 1/2 spin particle. However, I'm confused about Griffiths notation for the x and y components.
For the x component I got, ## \left< S_x \right> = \frac \hbar 2 (b^*a+a^*b)## which is correct, but Griffiths equates this to ## \hbar~Re(ab^*) ##.
For the y component I got, ## \left< S_y \right> = \frac \hbar 2 i (ab^*-a^*b)##, and Griffiths equates this to ## - \hbar~Im(ab^*)##.
All I know is that Re and I am refer to the real and imaginary parts of a complex number. Since we only have a factor of ##i## for the y component of spin, it makes sense why we use I am here, but I don't understand how ##Re(ab^*) ## or ## Im(ab^*)## absorbed the factor of 1/2. I also don't understand why for both, we have ## ab^*## only inside the indices, when for the x component we have the factor ##(b^*a+a^*b)## and for the y component after factoring out the minus sign, we have the factor ##(a^*b-ab^*)##. Thanks for any help with this.
The factor ##2## turned ##\dfrac{\hbar}{2}## into ##\hbar##.
These relations are true for any complex number...if you add the complex conjugate, the parts with the i in front cancel! And vice-versa
OK thanks. Well it looks like I need to just review complex numbers, because the factor of 2 and these relations aren't obvious to me.
Well, you add/subtract basically ##a+b## and ##a-b##, and then ##2## of the same are left.
What exactly was stopping you calculating ##Re(ab^*) ## and ##\frac 1 2 (b^*a+a^*b)##?
Even if you didn't immediately recognise this, what stops you checking these are equal?
I’m not sure what lead you to this assumption that I didn’t try. I did try, and then came here when it was clear I was missing something. The previous comments gave me some clues of what I need to review, so I will be continuing to try.
It turns out my problem was in making an embarrassingly simple mistake. I often have erroneously thought of numbers like ##a## or ##b^*## as merely real numbers or a real number with a factor of ##i## attached, and not like the complex number, ##z=x+iy##. With this in mind I was then able to take ##Re(ab^*)##, and have ##a=w+ix## and ##b^*=y-iz##. Working out ##b^*a+a^*b## and ##ab^*-a^*b##, I was able to recover the correct relations. Thanks for the help everyone!
Isn't this simply due to
$$\text{Re} z=\frac{z+z^*}{2}, \quad \text{Im} z=\frac{z-z^*}{2\mathrm{i}}$$
for any ##z \in \mathbb{C}##?
I think the OP has already admitted that he misunderstood what is meant by ##b^*##. I think he assumed ##a, b## were real and that ##b^* = bi##.
  • · Replies 32 ·
