Confused about the principle of least action
The discussion centers on the principle of least action in Lagrangian mechanics, specifically addressing the correct interpretation of the action integral S and the notation δ. The user initially confuses δ as a time derivative, while it actually represents a change in path. The correct application leads to the Euler-Lagrange equations, which are fundamental to deriving Newton's Laws. The conversation emphasizes the importance of consulting reputable texts on Lagrangian Mechanics or Calculus of Variations for accurate understanding.
  • Understanding of Lagrangian Mechanics
  • Familiarity with the concept of action integral S
  • Knowledge of Euler-Lagrange equations
  • Basic principles of Calculus of Variations
  • Study the derivation of Euler-Lagrange equations in Lagrangian Mechanics
  • Read "Calculus of Variations" to grasp the concept of path changes
  • Explore resources on the principle of least action in classical mechanics
  • Investigate the relationship between Lagrangian mechanics and Newton's Laws
Students of physics, particularly those studying classical mechanics, as well as educators and anyone seeking to deepen their understanding of Lagrangian dynamics and the principle of least action.
nomadreid
To make the confusions both concise and explicit, I will put down some incorrect calculations, and ask for corrections
Take the Lagrangian KE - PE = T - V
Action = S=∫ L dt (with given limits)
Principle of least action: δS= 0: S(t1)-S(t2) =0 if t1-t2 is small (using the (.) as function notation, not multiplication)
I presume δ can be taken as d/dt
Then d(∫ L dt)/dt = L(t1)-L(t2) = T(t1)-T(t2)+V(t2)-V(t1)=0
Next: conservation of energy
KE+PE = k for some k
So d/dt (T+V) = dT/dt + dV/dt = 0
If this is true on all points on the interval (t1,t2), then T(t1)-T(t2)+V(t1)-V(t2) = 0
Putting the two equations together... but obviously I've already gone way too far into the gross errors, and would be grateful for corrections. Thanks.
Here's your error. The \delta denotes change in path, not time. Most decent books on Lagrangian Mechanics or Calculus of variations will do a good job of explaining this. The idea, is that you have your action, S. This is a function(al) of the path through space. So if you deform the path a very small amount, that is \delta S. The path for which that is 0, like in normal calculus, is a max or min. I'm not comfortable enough to fully describe the process without going back to a book first, but doing this comes up with the Euler-Lagrange equations which are equivalent to Newton's Laws. I'm sure you can find a derivation online if your book isn't clear.
Thank you, DrewD. That helped very much.
  • · Replies 19 ·
  • · Replies 19 ·
