Confusing about Maxwell-Boltzmann distribution in non-classical region
The discussion revolves around the application of the Maxwell-Boltzmann distribution in transitioning from classical to quantum mechanics, particularly concerning momentum and wavenumber distributions. Participants question whether simply substituting the Planck constant into the momentum relation is a valid method for non-interacting systems, especially when considering bosonic gases at low temperatures. There is confusion regarding the dimensional analysis of the proposed expressions, specifically the need for distributions to be dimensionless. The correct relationship between the distributions f(p) and f(k) is emphasized, indicating that proper conversion must account for the dimensions involved. The conversation highlights the complexities of applying classical statistical mechanics principles in quantum contexts.
KFC
Hi there,
I am reading some materials on statistical mechanics and for the section on momentum distribution, there mention for some non-interacting system, the momenta distribution are satisfying the Maxwell-Boltzmann distribution, which is summarized in http://en.wikipedia.org/wiki/Maxwell–Boltzmann_distribution
If we consider the problem as 1 dimensional, the momentum distribution becomes
f(p) = [m/(2\pi k_B T)]^{-1/2}\exp[-p^2/(2mk_BT)]
This look good to me. But in some books or materials, for getting into quantum region, the author simply considers the non-interacting system by introducing the relation with Planck const. as
p = \hbar k
such that
f(k) = \hbar[m/(2\pi k_B T)]^{-1/2}\exp[-(\hbar k)^2/(2mk_BT)]
My question is, is that really the correct way to go from classical into quantum mechanics by just introducing the \hbar in the momentum relation to the wavenumber for the non-interacting system? As I have noticed in other book for statistical mechanics, the Maxwell distribution can only be applied for the system with the hypothesis that the particles are non-interacting, identical but distinguishable. But for quantum case, I don't know how this condition is hold. Since the author trying to apply the above distribution to a bosonic gas at really low temperature (call BEC?), should this condition hold for this case? But even that's true, why don't we use the boson statistics instead?
For my second question, if f(k) is the correct distribution, how come this quantity \hbar[m/(2\pi k_B T)]^{-1/2} has the unit of wave number? I try to do the math but I get meter square instead.
Something is wrong with the first equation. Just doing dimensional analysis, we have to have f(p)dp be dimensionless so f(p) has to have units of 1/(mv). It has units of the square root of kT/m. kT is an energy so the units are v^2, not 1/(mv). The correct statement is the square root of 1/(2\pi m k T)
Ok. Thanks. So what's the right expression for the quantum case when the wavenumber distribution being consindered? I try
f(k) = \hbar\sqrt{\frac{1}{2\pi m k_B T}} \exp[-(\hbar k)^2/(2mk_B T)]
but the dimension is not correct.
For a distribution of any variable x, you have to have f(x)dx be dimensionless. So you have to use f(p)dp=f(k)dk, which means f(k)=f(p) dp/dk, that should give you the right answer.
Thanks. But that's what I did, not working. since p=\hbar k and dpdk = \hbar, plug that back to the f(p) with p written in k, I got the one I wrote before but the dimension is not correct. The right dimension should be in meter^{-1}
Since k has dimensions 1/meter, and f(k)dk is dimensionless, f(k) must have dimensions of meters.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
