Confusing differential equation
aces9113
Determine the solution to the initial value differential equation: y'=0.0016 y (1800 − y), y(0)=66
Getting x's on one side and y's on the other and integrating. Then solve for c
I'm in calc 2 and this is the first time we are really being introduced to differentials so I put all the y's and dy on the same side and ended up with 0.347222ln(y)-0.347222ln(y-1800)=x+c.
The y integration I did on wolfram because I was unsure how to proceed so it migh be wrong. When I try to solve for y, I get a negative in the natural log which I can't do, although there must be an answer. Please help!
The integral of dy/y=ln(|y|). That formula works for negative values of y as well. The derivative of ln(y) is 1/y and so is the derivative of ln(-y). I guess Wolfram Alpha left that possibility out. You should probably try and do the integration yourself. It's just partial fractions.
Thank you very much for the help. Would it be possible for anyone to check my work, I got y=(2.88*e^(x)+64.43653296)/(0.0016*e^(x)+1.0357980739) but apparently this is wrong
