Confusion about induction in conductors
17 replies · 4K views · last reply
timetraveller123
Two-part diagram of a conducting sphere of radius R: left, a sphere with two concentric circles labelled a and b; right, a larger sphere with two hollow cavities marked a with charge qa and b with charge qb, and a radius R line.
a) charge induced is
##\frac{-q_i}{4 \pi r_i^2} = \sigma_i##
##\frac{q_a + q_b}{4 \pi R^2} = \sigma_R##
b) field outside is ##\frac{k (q_a + q_b)}{r^2}##
c)i naively applied gauss law to get field within each cavity as
##\frac{k q_i}{r_i^2}##
d) i was assuming the only field in the cavity is due to charge itself only and due to induced charge on the inner surface hence force = 0 which is correct
but part e confuses me
e)
the provided answer
Printed statement (e): sigma_R changes but not sigma_a or sigma_b; E_outside changes but not E_a or E_b; force on q_a and q_b still zero.
how could ##sigma_r## change and still have the ##\sigma_a## and ##sigma_b## constant while the conductor is neutral
furthermore this another text states
"The field inside the cavity depends only on the charge q and on the charge that gets induced on the inner surface of the cavity."
how could the induced surface charges affect the field inside if they are not included in the Gaussian surface
  • Two-part diagram of a conducting sphere of radius R: left, a sphere with two concentric circles labelled a and b; right, a larger sphere with two hollow cavities marked a with charge qa and b with charge qb, and a radius R line.
  • Printed statement (e): sigma_R changes but not sigma_a or sigma_b; E_outside changes but not E_a or E_b; force on q_a and q_b still zero.
In part (e) bringing the third charge near the conductor pushes charges around on the surface thus changing the distribution of surface charges but not the total charge on the surface. Because the electric field is zero inside the conductor and remains zero, what goes on inside does not affect what's outside and vice-versa.
Charges communicate with other charges via electric fields. Since there is no electric field inside the conductor, that line of communication is severed. The induced surface charges do not affect the field inside for that reason. I think you misunderstood what the textbook meant, namely that the field inside the cavity depends only on the charges that are placed inside the cavity and the surface distribution on the inside surface of the cavity. If you place a charge +q inside a cavity in a conductor, the total induced charge on the inner surface will be -q regardless of the shape of the cavity. However, the electric field inside the cavity will depend on the shape. A spherical cavity will have a different field inside it from a cube-shaped cavity. Don't forget that electric field lines have to be perpendicular to the conducting surface.
so is this what you are saying
when there was no third charge, the ##\sigma_R## was evenly distributed on the surface of the conductor but when the third charge was placed ##\sigma_R ## just redistributed itself and in sense "the magnitude of "##\sigma_R## did not change
this i understand is to make the field in the conductor zero
this is what i don't understand
Diagram of a conducting body with an inner cavity: a small point charge marked +q sits inside the cavity, a -q charge sits on the inner cavity surface, and a +q charge is on the outer surface.
now is the -q charge referred to as the surface charge induced on inside cavity i don't see how could the -q surface charge affect the field inside the cavity
if we draw a gaussian surface inside the cavity enclosing only the +q charge then the field inside is only due to +q charge and that was the answer to part c which was correct
so what do you mean by
i hope you can understand what is tripping me up thanksedit :
upon more careful thinking i am realizing that the E.da in gauss law is the net flux and and to which the surface charge does not contribute but that does not mean the field due to the surface charge is not there
  • Diagram of a conducting body with an inner cavity: a small point charge marked +q sits inside the cavity, a -q charge sits on the inner cavity surface, and a +q charge is on the outer surface.
when there was no third charge, the σR\sigma_R was evenly distributed on the surface of the conductor but when the third charge was placed σR\sigma_R just redistributed itself and in sense "the magnitude of "σR\sigma_R did not change
Yes, that's what I'm saying.
Good.
Yes, I agree that part (c) is correct. However, I suspect that you think that the electric field inside the cavity will be ##kq_i/r_i^2## no matter where the charge is placed or what the shape of the cavity is. This result is correct only in the highly symmetrical case of a spherical cavity with the charge at its center. That's what I wanted to clarify.
um i just edited it would you mind looking at it
i am thinking that my problem is just with what's going on in the cavity so let me just focus on the cavity say we have arbitrarily shaped cavity containing a charge q then on the outside there is -q induced charge
Diagram of a conductor with an irregularly shaped cavity; a circular region inside the cavity is labelled +q and the outer surface of the conductor is labelled -q.
what i am saying is that where the geometry permits isn't it possible to construct a sperical gaussian surface with the charge in the centre to conslude that ## \vec{E} = \frac{k q}{ r^2}## and in other parts of the cavity we will have to take into account the dot product and the surface charge is that what you are saying
  • Diagram of a conductor with an irregularly shaped cavity; a circular region inside the cavity is labelled +q and the outer surface of the conductor is labelled -q.
Yes the surface charge is there and affects the field. Gauss's Law is always valid. What you cannot always do is say that
$$\int{\vec{E}\cdot \hat{n}dA} =E\int{dA}$$
This happens when the electric field is perpendicular to the Gaussian surface and constant everywhere on the Gaussian surface.
yes now i get it one last question in the case of electrostatic shielding we know it is something like this (although the field lines bend)
Diagram of a circular conductor in a uniform external electric field: parallel arrows enter from the right and exit on the left, with pink dots on the left side marking positive charge and black dots on the right side marking negative charge.
where black is negative charge and pink is positive charge
but what if a external electric field pierces the conductor radially at all parts like this
Diagram of a circle with four straight field lines, each with an arrowhead, entering the circle from the top, bottom, left and right sides, all pointing toward its centre.
at equal magnitude at all point then how can the charges redistribute themselves i don't see any possible way thanks
  • Diagram of a circular conductor in a uniform external electric field: parallel arrows enter from the right and exit on the left, with pink dots on the left side marking positive charge and black dots on the right side marking negative charge.
  • Diagram of a circle with four straight field lines, each with an arrowhead, entering the circle from the top, bottom, left and right sides, all pointing toward its centre.
Suppose you draw a Gaussian surface just above the surface of the conductor. You have negative electric flux through that surface. What is the inescapable conclusion according to Gauss's Law?
oh my i completely forgot it is a negative charge wow that is very elegant indeed
but is there any way to direct the electric field radially towards a neutral conductor by external means ?
would that just crush the conductor?(due to electrostatic pressure)
You can place the neutral conducting sphere concentric with a conducting shell. You connect the outer shell to the positive terminal of a dc power supply and the sphere to the negative terminal. (I am describing a charged spherical capacitor.) In the region between the shell and the sphere you will get radial electric field lines as you imagined. Will the inner sphere be crushed if you crank up the power supply? Don't forget that if the outer shell is positively charged and the inner sphere has uniformly negative charges on its surface moved there by the power supply. There will be attraction between the positive outer charges and the negative inner charges so that the inner sphere will tend to explode rather than be crushed. Can you have the radially inward electric field without a negative charge in the center? The answer is no because that would violate Gauss's Law as indicated in post #9.
sorry for the late reply i was thinking what would happen
if we were to plop down a ring of positive charge around the metal sphere the field only cancels out in the centre so there might still be some radial field at points off the centre then what happens in that situation will the metal sphere be repelled by it somehow
vishnu 73 said:
... will the metal sphere be repelled by it somehow
Keep in mind that in a conductor some of the electrons are free to move around in response to electric fields. They will move and keep on moving until the electric field inside the conductor becomes zero. This happens very fast. As a result, any electric field lines on the outside that impinge on the conductor, must stop at the surface. If the lines are generated on the outside by positive charges, they start there and end on the conductor's surface. If the outside charges are negative, electric field lines start on the surface of the conductor and end at those negative charges. This is another way of saying that the induced charges on the surface of the inductor have polarity that is always opposite to the outside charges as the free electrons in the conductor are attracted by negative external charges and repelled by positive external charges. Even if the conductor is neutral, there will be separation of charges inside it and you will have opposite charges on the surface in closer proximity than the charges of the same polarity. This makes the net force between the external charges and the conductor always attractive.
ok now i see it but one last question
say considering the same positive ring of charge
inside the ring the field points radially inwards again except for at the origin where it is zero but inside the ring there is no charge but any Gaussian envelope will net negative flux what is solution to this do i have to consider it in three dimensions ?
vishnu 73 said:
... inside the ring the field points radially inwards again except for at the origin where it is zero.
Not really. See simulation of electric field lines due to a ring of charge in Figure 29 here.
http://web.mit.edu/8.02t/www/802TEAL3D/visualizations/guidedtour/Tour.htm#_Toc27302329
vishnu 73 said:
... do i have to consider it in three dimensions ?
Of course. How else are you going to enclose a volume with a Gaussian surface?
so while there is "negative divergence" in the xy plane but in total when considering the three dimension there is also some positive divergence hence exactly canceling out?
nice link by the way thanks!
Exactly.
