What are the differences between the two package types for MIC29302?
  • Thread starter Thread starter bitfoic
    Confusion
The MIC29302 series features multiple package types, specifically three surface mount (SMD) and three through-hole (TH) variants, which differ primarily in pin configuration. The pin shapes include straight pins for TH mounting and bent pins for SMD applications. The part number suffix indicates the specific package type, which is crucial for ensuring compatibility with circuit board designs. Users must refer to the manufacturer's datasheet for detailed specifications and to confirm the correct part number for their assembly needs.
  • Understanding of SMD and TH mounting techniques
  • Familiarity with reading electronic component datasheets
  • Knowledge of part number suffixes and their significance
  • Basic concepts of thermal and electrical specifications in electronics
  • Review the MIC29302 series datasheet for detailed package specifications
  • Learn about the differences between SMD and TH components
  • Research how to interpret part number suffixes for electronic components
  • Explore the implications of thermal and electrical specifications on component selection
Electronics engineers, PCB designers, and anyone involved in selecting or assembling components for circuit boards will benefit from this discussion.
bitfoic
Hi, everyone! I am new here with my confusion. I search a part MIC29302 as I was looking for its datasheet. I know MIC29302 is a series. I check the part information on the website called [Spam reference redacted by the Mentors] and its official manufacturer microchip. I found that there are two images of this part on both two websites. The five pins in one of the images are bent and another is straight. What is the difference between the two types of pins? Is the difference only in the package? I am not sure whether I am right. Who can solve my confusion?
With the same basic part number, the function of the two chips would be the same.
If you look at the last few pages of the data sheet(s) you will probably find that the final few characters of the part number (actually ordering number) differ between the two. That way you can order the pin shape you need for your particular assembly.
Since you did not give a link to the parts in question, I did not look them up specifically.
From your brief description I am assuming that one of the styles is for "thru hole" mounting on a circuit bouard where holes are drilled thru the board so that the pins are inserted into the holes and then soldered.
The other style would be where the pins are bent outward, away from the package, so they can be placed on the surface of a circuit board and then soldered, "surface mount".
Hope this helps.
Cheers,
Tom
If you found only two packages, then you missed some. According to the full series datasheet, it's three SMD and three TH types, with three (fixed voltage) or five (adjustable) pins.
The part number composition for the series is even more of a mess.
It's a bother, but always dig till you find the complete datasheet, and then try to link up the part numbers, functions and package info according to that and that only.
To add to the confusion for exactly the same silicon it is possible some chips will have pins bent "inward" (under the chip itself) and some will have no legs at all, just contacts on the belly. Plenty of different packages.
But the devil is in the details, there is no standard way of naming such chips and actually there is no way to be sure what you have/need - even full datasheet from the manufacturer can be sometimes misleading.
The different packages are usually specified in the part number suffix.
Where the thermal or electrical specifications differ for different package types, there will be multiple columns for the specification data.
The last few pages of a datasheet usually give the physical dimensions of the different packages available.
The manufacturer's datasheet is worth reading.
https://ww1.microchip.com/downloads...urrent-Low-Dropout-Regulators-DS20005685B.pdf
  • · Replies 33 ·
