Confusion about the potential reference point
The discussion focuses on the concept of electric potential and its reference points, specifically addressing the confusion surrounding the potential at a point z with reference to infinity versus a point z=0. The participants clarify that the reference point for potential can be chosen arbitrarily, and in this case, it is set at the origin (Φ(0)=0). The potential of a charged ring is derived by integrating the Coulomb potential, leading to the expression V(z)=\frac{\rho_s}{2\epsilon_0}(\sqrt{a^2+z^2}-\sqrt{b^2+z^2})+C, where C is an arbitrary constant that can be adjusted to ensure V(0)=0.
  • Understanding of electric potential and voltage concepts
  • Familiarity with Coulomb's law and electric fields
  • Knowledge of definite integrals in calculus
  • Ability to manipulate mathematical expressions involving constants
  • Study the derivation of electric potential from electric fields using integrals
  • Learn about the implications of choosing different reference points for electric potential
  • Explore the properties of the Coulomb potential and its applications in electrostatics
  • Investigate the concept of potential energy in electric fields and its relation to work done
Students and professionals in physics, particularly those studying electromagnetism, electrical engineers, and anyone involved in theoretical or applied physics related to electric fields and potentials.
jegues
See figure attached for problem statement, solution provided and my solution.
I'm getting confused about the reference point for the potential.
First find the potential at point z with reference at infinity,
\phi(z) - \phi(\infty) = \alpha
Now find the voltage at point z=0 with reference at infinity,
\phi(0) - \phi(\infty) = \beta
Now the potential at z with the reference at z=0, which is the same as the voltage difference between the individual voltages at z and z=0 with their reference point at infinity. (Is this statement true?)
\alpha - \beta = \phi(z) - \phi(0)
The question wants me to solve for,
\phi(z)
but it seems as though I've given them,
\phi(z) - \phi(0)
What am I interpreting differently? What am I confusing myself with?
Thanks again!
The reference (zero) point of the potential can be chosen anywhere. Here it is at the origin instead of infinity: Φ(0)=0. Just think, how would you substitute infinity for z into the potential function here? In practice, only the potential difference counts.
When calculating the definite integral ∫dΦ = -∫Edz', integrate from z'=0 to z, then the left hand side becomes Φ(z) - Φ(0). No sense to use infinity.
ehild
ehild
I don't understand what you're trying to say with this line,
I don't have a potential function yet, in order to get it I had to calculate the potential at z with the reference at infinity. Are you making the assumption that I did this already?
Can you please clarify?
OK, I misunderstood the problem as i could not read the attached picture and your handwriting. I thought you integrated the electric field to get the potential. It is much better if you type in your work.
So the potential of the ring was calculated by integrating the Coulomb potential for the charge distribution. The Coulomb potential U=kQ/r has its zero value at infinity, and the resultant potential of the charged ring is also zero at infinity. But you can add an arbitrary constant to any potential function, so
is also a potential function of the same ring. Choose C so as V(0)=0.
ehild
ehild
This was the missing piece I was looking for!
So, C =\frac{\rho_s}{2\epsilon_0}(b-a).
Now completing the expression for V(z),
V(z) = \frac{\rho_s}{2\epsilon_0}(\sqrt{a^2+z^2}-\sqrt{b^2+z^2}) + \frac{\rho_s}{2\epsilon_0}(b-a)
And what is this potential at infinity ?:smile:
ehild
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 18 ·
