Connect Four in C#: Solving Stats Issues
  • Thread starter Thread starter Veronica_Oles
    Game
The discussion focuses on programming the game Connect Four in C# and addresses issues with tracking game statistics, specifically the tallying of ties and the incrementing of game counts. The code snippet provided reveals problems with the logic in the check_winner_v method and the handling of the winner variable. Participants emphasize the importance of using clear variable names and adding comments to improve code readability and maintainability.
  • C# programming fundamentals
  • Understanding of Boolean logic and conditional statements
  • Basic knowledge of event handling in Windows Forms
  • Familiarity with game development concepts
  • Implement better variable naming conventions in C#
  • Add comments to clarify code functionality and logic
  • Learn about debugging techniques in C# to identify logical errors
  • Explore data structures for managing game state in C#
C# developers, game programmers, and students learning about game logic and statistics tracking in programming.
Veronica_Oles
Need help programming the game connect four in C#.
Code:
private Boolean check_winner_v()
            Boolean winner = false;
            for (int i = 0; i < 7; i++)
                for (int j = 0; j < 3; j++)
                    if (board[j, i] == 1 && board[j + 1, i] == 1 && board[j + 2, i] == 1 && board[j + 3, i] == 1 || board[j, i] == 2 && board[j + 1, i] == 2 && board[j + 2, i] == 2 && board[j + 3, i] == 2)
                        winner = true;
                        if (board[j, i] == 1)
                            player1_wins = 1;
                            games++;
                        else
                            player2_wins = 2;
                            games++;
            return winner;
        private void button17_Click_1(object sender, EventArgs e)
            for (int i = 5; i > -1; i--)
                if (board[i, 1] == 0)
                    if (turn == 0)
                        board[i, 1] = 1;
                        two[i].BackColor = Color.Red;
                        turn = 1;
                        row2++;
                    else
                        board[i, 1] = 2;
                        two[i].BackColor = Color.Yellow;
                        turn = 0;
                        row2++;
                    two[i].Visible = true;
                    i = -1;
            if (row2 == 6)
                button17.Enabled = false;
                button17.Text = "Full";
            textBox1.Text = check_winner_v().ToString();
            textBox2.Text = check_winner_h().ToString();
            if (winner == false && turn == 42)
                textBox5.Text = tie.ToString();
                tie++;
        private void button68_Click(object sender, EventArgs e)
            init_board();
            for (int i = 0; i < 6; i++)
                one[i].Visible = false;
                two[i].Visible = false;
                three[i].Visible = false;
                four[i].Visible = false;
                five[i].Visible = false;
                six[i].Visible = false;
                seven[i].Visible = false;
            row1 = 0;
            row2 = 0;
            row3 = 0;
            row4 = 0;
            row5 = 0;
            row6 = 0;
            row7 = 0;
            turn = 0;
            games++;
            textBox1.Text = "";
            textBox2.Text = "";
            button28.Enabled = true;
            button16.Enabled = true;
            button16.Text = "";
            button17.Enabled = true;
            button17.Text = "";
            button18.Enabled = true;
            button18.Text = "";
            button19.Enabled = true;
            button19.Text = "";
            button8.Enabled = true;
            button8.Text = "";
            button20.Enabled = true;
            button20.Text = "";
            button21.Enabled = true;
            button21.Text = "";
I'm having trouble programming the statistics. My stats do not work:
For when the player tie it for some reason will not tally up the tie and this is the part that should tally it up but it does not.
tie++;
Games does not want to increment either, which is incremented in the method of check_winner_v.
I did not give entire program only parts that I thought were necessary.
Why do you check for the end of the game for each row separately?
Did you check which condition fails? Is it winner==false or turn==42?
Is the variable "winner" global? (Don't do that)
If yes, the second call of the winner function will override the result of the first one.
If no, where does the variable come from?
This line near the top of your code really stands out, but not in a good way. I have no way of telling what it's supposed to be doing, since there are no comments to help a reader understand its purpose. You have all of these Boolean expressions, with some connected with && and some connected with ||. If board[j, i] is true, the whole expression is true, regardless of the truth values of all of the other expressions.
Veronica_Oles said:
C:
If I were grading this program, I would take off points for 1) lack of comments, and 2) unhelpful variable names (e.g. the arrays named one, two, three and so on, and buttonX and textBoxY), even if the logic in the program was correct.
Why? I would expect the expression to be interpreted as
if ( ((board[j, i] == 1) && (board[j + 1, i] == 1) && (board[j + 2, i] == 1) && (board[j + 3, i] == 1)) || ((board[j, i] == 2) && (board[j + 1, i] == 2) && (board[j + 2, i] == 2) && (board[j + 3, i] == 2)))
In other words, if (field j,i is held by player 1 AND field j+1,j is held by player one AND ... AND ...) OR (those four fields are held by player 2), then the expression is true. Could get some comment about rows/lines and the meaning of 1 and 2, could get more brackets, but I don't think that is so bad.
mfb, you're right. Still, with such a long expression, adding parentheses as you did, or better yet, breaking it up into smaller chunks would help the reader comprehend what's going on.
I am well aware of the fact I have to add comments I have not gotten to that yet just trying to figure out the stats first.
10K
  • · Replies 33 ·
