Connecting Thermocouples to a Spinning Workpiece: Tips and Tricks
  • Thread starter Thread starter soonsoon88
    Machine Turning
6 replies · 2K views
soonsoon88
How to connect a wire to a workpiece which is spinning by turning machine ?
on Phys.org
What's the size of the application?
Other things to think about are cost, efficiency, time you're willing to commit, etc.
How about connecting the wire to your turning machine, which you could then relay the current through the turning machine.
You could also connect the wire through a bearing that is connected to the workpiece such that the wire doesn't move with your workpiece. You would have to be careful of how much torque the bearing would apply to the wire. In other words, make sure you lubricate in order to avoid breaking of the wire. Lubrication will decrease the amount of stress that is applied to the wire.
Thanks for reply. I only can connect the wire to the workpiece. Actually i want using Tool-Work Thermocouple method to measure the temperature when cutting steel. I search all the youtube, i can't find any similar thing in it. so, i am getting trouble. May i know when the bearing should put at ? on workpiece ? the size of workpiece just around 20 to 25mm..
I really need help =(
so you probably shouldn't use a bearing for that application. It's just way too small to use a bearing. The only other application I can think of is the one I mentioned before. I'll try to get a better understanding of the thermocouple you mentioned before and see if I can figure something out.
are you trying to find the temperature on the work piece? If so, you probably should research more thermocouples to find one that best fits your application. I don't know a lot about thermocouples. Also try posting this in the EE part as thermocouples are usually connected to a pc for readouts. Good luck and sorry I couldn't be of more help.
http://www.mfg.mtu.edu/marc/primers/heat/exp.html
You may have a look on that link.
I am using tool work thermocouple(a way of measure temperature when metal cutting)
I need to measure the temperature of workpiece when it is turning on certain speed or feedrate.
I got the idea how to connect wire to insert but just having a problem of connecting another wire to workpiece. The link i gave you just now is showing how they connect. but it troublesome for me. so, i need someone to help me think of another way >.<
