Conservation of Energy and Inertia resist acceleration
The discussion revolves around an experiment aimed at demonstrating the conservation of energy and the concept of inertia resisting acceleration through the rolling motion of various objects down a ramp. Participants explore the relationship between potential energy, kinetic energy, and the effects of inertia on acceleration.
  • One participant describes an experiment using rolling objects to test conservation of energy and inertia, noting that different shapes exhibit different timings due to varying inertia.
  • Another participant points out that the initial potential energy is converted into both translational and rotational kinetic energy, suggesting that both forms must be accounted for in the conservation of energy equation.
  • A participant presents a formula for calculating final velocity based on potential energy and kinetic energy, questioning whether it is valid to use this approach to prove the theory.
  • Concerns are raised about the use of the same variable for both translational and rotational kinetic energy, indicating a potential error in the calculations presented.
  • Further clarification is sought regarding the acceleration of rolling objects, with a participant referencing a specific formula for acceleration that suggests it differs from that of sliding objects, and questioning the origin of the constant factor in the formula.
Participants express differing views on the correct application of energy conservation principles, particularly regarding the treatment of rotational kinetic energy. There is also uncertainty about the acceleration of rolling objects and the validity of the formulas used, indicating that multiple competing views remain unresolved.
Participants note limitations in their understanding of the relationship between translational and rotational motion, and the derivation of acceleration for rolling objects. There are unresolved questions regarding the assumptions made in the calculations and the applicability of certain formulas to different shapes.
This discussion may be useful for students and enthusiasts interested in experimental physics, particularly those exploring concepts of energy conservation, inertia, and the dynamics of rolling motion.
zenite
Hi Guys, I am doing an experiment to prove
1) Conservation of Energy
2) Inertia resist acceleration
The experiment is simple, rolling objects down a ramp.
So I timed the time taken for each object to reach the finishing line from rest.
To prove conservation of energy, I increased the height of the ramp, and then the steepness of the slope (height remains the same).
So when the slope steepness changes, the final velocity (hence kinetic energy) remains the same for an object. When height changes (steepness remains constant), the final velocity changes (potential energy changes, hence final kinetic). Is this reasonable to conclude that conservation of energy is true? The object is assumed to be pure rolling, hence no frictional effects.
And then for inertia. I used different shapes, solid sphere, hollow sphere and hollow cylinder. I got different timing for the shapes. The larger the inertia the longer the time taken. So how do I go about explaining inertia resist acceleration?
1 thing that confused me here is that how can I calculate the final velocity of the object with the data I had. I have height, degree of slope, displacement, mass. How do I get the final velocity? Can anyone help here?
My approach:
I used conservation of energy equation, PE1 = KE2 to find my final velocity. But can I really use it if I am trying to prove the theory is true? I then tried using kinematics to solve. But then I have to assume acceleration is constant. Is it constant? and what is the acceleration? Because inertia resist acceleration, each object have a different acceleration, correct? I thought a=g sin(theta) initially, but I am sure that's wrong.
There is a problem.
You said that you are rolling objects down a ramp. The initial PE that you had at a particular height is being converted NOT just into the KE of the object via the translational motion, but also in the ROTATIONAL kinetic energy. So the energy is being converted into two different forms, not just into translational KE. To get the full conservation, you have to account for both.
Zz.
Yes, I do account for both. Will it affect the theory in any way?
The formula I used to calculate final velocity:
mgh = 0.5mv2 + 0.5Kmv2 where k is a constant dependable on shape of object (inertia)
so v = sqrt (2gh/(k+1))
Then I need to compare the theoretical velocity (the one above) with the practical one. problem is, how do I solve for final velocity? I have displacement and time. Is that sufficient? Can I can assume acceleration is constant, and if so what is the acceleration? Pls advice.
Where did you get that? You need to look up the expression for rotational KE. The fact that you are using the same "v" for both makes it incorrect.
Zz.
Sorry, I skipped some steps. Here is the full working, pls let me know if its wrong.
mgh = 0.5mv2 + 0.5Iw2
For pure rolling, v = rw
mgh = 0.5mv2 + 0.5(kmr2)(v/r)2 = 0.5mv2 + 0.5kmv2
The inertia formula is used as kmr2, if its a sphere, k=1.
For the acceleration down a ramp for a rolling object, I did some research and found this:
Rolling objects have lower translational acceleration than that of a sliding, hence a is not equals to g*sin(theta). From a website, it states that a = sin(theta)*g*5/7
Can anyone tell me where does the 5/7 comes from? It seems like it comes from the moment of inertia, so the formula only applies to a certain shape. How do I derive the acceleration? Is the acceleration of a rolling ball even constant in the first place? I would really appreciate it if someone clears my doubt on the last question.
  • · Replies 60 ·
  • · Replies 39 ·
  • · Replies 46 ·
  • · Replies 138 ·
9K
