Conservation of Energy Problems
15 replies · 5K views · last reply
eraemia
Consider a rock with mass m dropped from rest off a cliff of height h.
1. If we want to apply conservation of energy to the falling rock, what do we need to include in our system?
2. Let us set the gravitational potential energy V=0 when the rock is at the bottom of the cliff. With this convention, what is the gravitational potential energy and the kinetic energy of the system when the rock is at the top of the cliff?
3. What is the gravitational potential energy and kinetic energy of the system just before the rock hits the ground at the bottom of the cliff?
4. Using your answers to parts 2 and 3 as the end points, make a rough sketch of gravitational potential energy and kinetic energy vs. time during the entire period of the rock's motion from top to bottom of the cliff.
KE = 1/2 m v^2
PE = mgz
1. earth, rock, and cliff?
2. PE = m * 9.8 m/s^2 * h; KE = 0?
3. PE = m * 9.8 m/s^2 * h? KE = (1/2)m(h/t)^2?
4. Is this like an x-y graph, where x is time and y is energy? if so, then gravitational energy would be like a straight line from top to 0, and KE would be like from the origin to the top right, so like two straight lines criss-crossing; an X
Number 3 is wrong. how are you getting mgh at the bottom when the gravitational potential energy at the top is mgh?
well i wrote mgh, because i don't know any information other than the variables..i don't know the height and m and g are constants.
or, do i know the height? it's not 0 since the question says right before. so what should h be, or how can i calculate it? thanks
the height is 0 at the bottom... gravitational potential energy = mg(0) = 0... also the question says that the gravitational potential energy is taken to be 0 at the bottom.
yes, the height is 0 at the bottom, but question 3 asks what is the gravitational potential energy just before the rock hits the ground. in other words, it hasn't reached height = 0 yet..
I think they mean for you to take height = 0. The reason they say "before the rock hits the ground" is so that you know that a collision hasn't taken place... because once it hits the ground we have more to deal with than kinetic energy and gravitational potential energy... we have heat, sound etc...
Alright, what about KE final? Is it KE = (1/2)m(h/t)^2?
And does 4 look right?
Thanks for your help, learningphysics.
No. that's not right. Use conservation of energy. What is the total energy at the top? What is the total energy at the bottom? What must the kinetic energy at the bottom be?
they won't be straight lines though... try to get the equation for kinetic energy in terms of time.
ok, i think i got it
conservation of energy is 0 = change in kinetic energy + change in potential energy
so (Kf - Ki) + (Vf - Vi)
since Ki and Vf = 0, we get
0 = Kf - Vi, which is
0 = (1/2)mv^2 - mgh
solving for v, we get
v = sqrroot(2gh)
is that right?
now how do i graph this as an "endpoint" i don't quite get that
0 = (1/2)mv^2 - mgh
v = sqrroot(2gh)
is that right?
Yes. What is the kinetic energy at the bottom before it hits the ground?
KE = (1/2)mv^2
What is v in terms of time?
Okay, so if vf = sqrroot(2gh), then Kf = (1/2)m(2gh) = mgh (?)
that looks like potential energy...is that right?
now vf = sqrroot(2gh)..
there's no t except in "g"
perhaps i can extract it somehow
v^2 = 2gh
[ (1/2)v^2 ] / h = 9.8 m / s^2
[ [ (1/2)v^2 ] / h ] / 9.8 m = s^2
sqrroot[ [ (1/2)v^2 ] / h ] / 9.8 m] = s
well that gives me seconds, which is time, right?
well, if not straight lines, then curves, right? KE would curve from origin to top right and PE would curve from top left to bottom right 0, right?
EDIT: also, I added "air" to #1, is that right? since the question doesn't specify whether to consider a frictionless free fall or not...
yes... but there is a simpler way to look at it. Energy is conserved. The total energy at the top is mgh (gpe = mgh ke = 0). By conserveration of energy, total energy will remain mgh (until a collision or something takes place)... so total energy at the bottom is also mgh. we know that gpe = 0 at the bottom... KE + gpe = mgh, KE + 0 = mgh... so KE = mgh at the bottom.
you almost did the same there here with:
Also, when you did so (Kf - Ki) + (Vf - Vi)
At this point you could have continued with:
Kf = Vi
Kf = mgh
and finished there.
Now, what is v in terms of t... using the knowledge that acceleration is -g? You know that v0=0.
If energy is conserved, then air does not belong to the system?
Okay, could you give me some more pointers with "what is v in terms of t"?
This was my previous attempt:
v^2 = 2gh
What did I do wrong? And what is the purpose of solving v in terms of t? For the graph? I'm a little confused. Thanks again.
yes. we'd leave air out of the system... otherwise you have to deal with energy lost to the air etc...
v^2 = 2gh
Well... v is undergoing constant acceleration... so therefore v = v0 - gt = 0 - gt = -gt
Then substitute into KE = (1/2)mv^2
so KE = (1/2)m(-gt)^2 = (1/2)mg^2t^2
Yes, the reason is for the plot... now you can see how KE changes with time.
Now, you can also get gravitational potential energy at any time t, using the knowledge that total energy is mgh
Now is this: KE = (1/2)mg^2t^2
total KE?
because i already established that KEi = 0 and KEf = mgh; the sum should be mgh, right?
i don't understand what this KE is
total KE?
You need to plot KE vs. time, and potential energy vs. time...
You know KE at the top = 0. so at t = 0, KE = 0. You know KE at the bottom = mgh... but what is KE in between (while it is falling)?
