Conservation of linear momentum & center of mass
The discussion centers on the conditions under which the center of mass (c.o.m) frame of reference remains inertial when two cars accelerate. It is established that for the c.o.m to be inertial, the net external forces must equal zero, leading to the equation m1a1 + m2a2 = 0. This means that the cars exert equal and opposite forces on each other, consistent with Newton's Third Law. The conversation also clarifies that a frame is considered inertial as long as it is not accelerating, even if external forces like friction are present, as long as the cars maintain constant velocities initially. Ultimately, linear momentum is conserved in this scenario, as the internal forces cancel out, allowing observers in the c.o.m frame to interpret the situation without needing fictitious forces.
yoni162
Two cars are driving along the road at constant speeds V1, V2. At t=0 they begin to accelerate with constant acceleration a1, a2. Under what circumstances is the center of mass frame of reference inertial?
Fext=0 ==> change in momentum=0
It's known that if there are no external forces acting on a system, the momentum is conserved. The same applies if there are external forces present, but they cancel each other so that the net external force is 0 (correct?). Now, from the center of mass (c.o.m) frame of reference, when the momentum is conserved, the total momentum is 0. Would that apply if despite the fact that there are external forces acting on the cars, if with their acceleration, the velocity of the c.o.m is kept the same (thus making it inertial)? Or is Fext=0 necessary in order for that to happen?
You are on the right track, so I will help you see through this. Suppose you are on a skateboard moving along at the velocity of the center of mass before the cars start accelerating. Now at t = 0 they start accelerating. How must the accelerations of the cars be related for you to say that Newton's Laws are obeyed and you need no fictitious external force to explain what you see?
OK I don't know if that's what you were going for, but I said: in order for the c.o.m frame of reference to remain inertial, we need to have the the net external forces=0.
I know that the net external forces is the velocity of the c.o.m divided by the sum of the masses, and I want it to be 0, meaning (in a one-dimensional case):
m1a1+m2a2=0
Is that true?
Also, how do I explain the fact that the original frame of reference is inertial to begin with, considering there's friction acting on the cars? Or do I say that because V is constant (for each car), the net force is 0 so there's really no problem here, even though the forces are external?
m1a1+m2a2=0
Is that true?
It is. If the above condition is satisfied, the center of mass does not accelerate, i.e. it is an inertial frame. Furthermore, an observer in that frame will interpret the above condition to mean that the two cars exert equal and opposite forces on each other in accordance with Newton's 3rd Law, i.e. all forces appear to be internal to the two-car system.
Correct. A frame is inertial as long as it is not accelerating. When both cars are moving at constant velocity, their center of mass is not accelerating.
One more thing I wanted to ask..is there conservation of linear momentum in this case? Since the forces acting on the cars aren't internal forces after all..
This is a philosophical question. If you define, strictly, that momentum is conserved as long as the center of mass does not accelerate, yes, linear momentum is conserved. The non-conservation of linear momentum when external forces act on the system comes about when internal forces act in pairs. Here, if m1a1+m2a2=0, internal forces cancel in pairs. Therefore, by the strict definition, linear momentum is conserved. An observer in the CM frame will not be able to tell otherwise although he/she may have to account in some way or another for the action-reaction apparent force between the cars. In accelerating frames, one has to invent fictitious external forces; this is a special case where one has to invent a fictitious internal force.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
