Conservation of Mechanical Energy
The discussion centers on applying the conservation of mechanical energy to solve a physics problem involving a block and a solid cylinder. The block, with a mass of 2 kg, falls 82 cm in 2 seconds, leading to the calculation of its velocity and acceleration. Key equations include the potential energy (PE) and kinetic energy (KE) formulas, specifically PE = KE(block) + KE(cylinder). The radius (R) of the cylinder is determined to be unnecessary for the calculations as it cancels out in the energy equation.
  • Understanding of conservation of mechanical energy principles
  • Familiarity with kinematic equations
  • Knowledge of potential and kinetic energy formulas
  • Basic algebra for solving equations
  • Study the derivation of the conservation of mechanical energy principle
  • Learn about the relationship between linear and rotational motion
  • Explore the implications of massless strings in physics problems
  • Investigate more complex systems involving pulleys and cylinders
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators seeking to clarify concepts related to rotational dynamics and energy calculations.
Lma12684
A massless string is wrapped around a solid cylinder as shown in the diagram. A block of mass 2kg hangs from a string. When released, the block falls a distance of 82 cm in 2.0 seconds. Calculate the mass using the conservation of mechanical energy.
d=speed(i) + 1/2at^2
a=.205 m/s
V(f)=v(i) + at
v(f)=.41 m/s^2
PE=KE(block) + KE(cylinder)
mgy=1/2mv^2 + 1/2(1/2MR^2)(v/r)^2
The problem is that I do not know how to find R? Please help!
Hi Lma12684,
I think you neglected the 1/2 in your equation when you calculated a.
For the value of R, what do R and r represent in your final equation?
My apologies, they represent the radius. I didn't mean to use different symbols.
So you can see now why you do not need to know the radius?
Because they cancel??
That looks right; once you correct a and vf I think you can solve the energy equation.
Thank You~!
  • · Replies 37 ·
