Conservation of Momentum and Thrown Objects
The discussion focuses on solving a physics problem involving the conservation of momentum with a stationary canoe and a girl throwing two cannonballs. The correct final velocity of the canoe, after accounting for the throws, is determined to be approximately -0.87 m/s. The solution involves applying the law of conservation of momentum in two steps, first considering the velocity after the first throw and then after the second throw, while switching frames of reference. The key takeaway is that the velocities of the thrown objects must be calculated with respect to the canoe's motion after each throw.
  • Understanding of conservation of momentum principles
  • Ability to perform calculations involving vector addition
  • Familiarity with frame of reference concepts in physics
  • Basic knowledge of Newton's laws of motion
  • Study the application of conservation of momentum in multi-object systems
  • Learn about frame of reference transformations in physics problems
  • Explore examples of momentum conservation in real-world scenarios
  • Practice solving similar problems involving moving and stationary objects
Students in physics courses, educators teaching momentum concepts, and anyone interested in understanding the dynamics of moving objects in relation to stationary frames.
Jessehk
[SOLVED] Conservation of Momentum and Thrown Objects
As part of our physics class, we've been given lots of problems typically solved by taking into account the law of conservation of momentum. I've had little-to-no trouble solving them, but one problem in particular is driving me nuts.
There is a 50 kg girl in a 50 kg stationary canoe holding 2 10 kg cannon balls. She throws a cannon ball at 5 m/s, and then throws the second at 5 m/s w.r.t the boat. What is the canoe's final velocity if the (incorrect) assumption is made that their is no friction between the canoe and the water? Answer: 0.87 m/s
<br /> \vec{p} = \vec{p \prime}<br />
Ok, so I first calculate the speed of the canoe w.r.t the ground using the law.
<br /> 0 = \vec{p_c} + \vec{p_b}<br />
<br /> 0 = 110 v_c + 10(5)<br />
<br /> v_c = -5/11 m/s \approx -0.454545454... {m/s}<br />
Next, my idea was that the fact the second ball is being thrown at 5 m/s w.r.t. the canoe while the canoe was moving was important. So I used the L. of C. of M. again but in the frame of reference of the canoe.
<br /> 0 = 100v_c + 5(10)<br />
<br /> v_c = -1/2<br />
So I figured I would just add the speed in the frame of reference of the boat to the speed it was traveling before. That gives me
<br /> v_c \approx -0.95454545... m/s<br />
Which is clearly not the right answer. Am I on the wrong track completely, or is there something simple I've missed? Any help would be appreciated. :)
When she throws the balls at 5 m/s with respect to the canoe, they mean with respect to the canoe after the ball is thrown. If the canoe's velocity (after the throw) is Vc (negative, of course), the ball's velocity is Vc + 5.
Thanks Doc Al. If I'm not mistaken, that leads me to this answer:
<br /> \vec{p} = (-5/11)(110) = \vec{p \prime} = 100v_c + 10(-5/11 + 5)<br />
<br /> -50 = 100v_c + 500/11<br />
<br /> v_c = -0.9545<br />
Which is the same as my previous attempt. I think that makes sense, as I've just switched frames of reference. What am I doing wrong?
Looks to me like you're adding 5 m/s to the speed of the canoe before the throw, not after like I suggested.
I'd do it in two steps, having both throws be 5 m/s with respect to the canoe after the the throw. (The idea of changing frames is a good one; use that for the second throw.)
When you say after the throw, do you mean after the first ball is thrown (before which, the canoe is stationary), or after the second ball is thrown by the girl on the moving canoe?
After each throw. (That's how I would do it.)
Find the speed after the first throw (with the ball being 5 m/s w.r.t. the canoe after the throw). Then repeat (after switching frames) for the second throw.
Doc Al! Thank you so much for that help. It was exactly what I needed: it gave strong hints, and forced me to think.
In case anyone is interested:
<br /> 0 = 110 v_c + 10(v_c + 5)<br />
<br /> v_c \approx -0.417 m/s<br />
In the frame of reference of the boat...
<br /> 0 = 100v_c + 10(v_c + 5)<br />
<br /> v_c = -5/12 m/s<br />
Get back to the ground frame...
<br /> v_c = -5/12 - 5/11 \approx -0.87 m/s<br />
Yay!
EDIT: it could arguably be solved more simply in the ground frame, but I find it easier to visualize in the canoe frame.
  • · Replies 19 ·
