Conservation of momentum - Collision of pool balls
Momentum is conserved in collisions, and to solve the problem of two colliding pool balls, it's essential to resolve their velocities into x and y components. The orange ball moves west at 15 cm/s, while the green ball moves at 15 cm/s at an angle of 30 degrees east of north, which translates to 60 degrees from the x-axis. A vector diagram can help visualize the collision, with the orange ball represented as a vector in the negative x direction and the green ball's components calculated using sine and cosine. After calculating the momentum in both the x and y directions, the resulting velocities can be determined. This approach ensures that momentum conservation principles are correctly applied to find the final velocities after the collision.
crazedbeat
Hi,
I am having trouble recalling my concepts in momentum. I just remember its conserved :rolleyes:
Plus, I am horrible with directions, so need help understanding this problem, as well as the underlying concepts.
Two pool balls are rolling along a pool table. The orange pool ball has a velocity of 15 cm/s west and the green ball a velocity of 15 cm/s north 30° east. What are the velocities of the balls after the collision?
What I am doing is as follows:
15*m + 15*m = m(15 + 15)
which doesn't take me anywhere
Do I need to resolve into x and y components?
So any help on this question would be greatly appreciated. I will try and return the help by helping others. (i.e. pay it forward!)
Yeah, you need to resolve the velocities into components.
Okay, so if I resolve them, what exactly does North 30 degrees east mean? Is it north or east or north east? If its north east, what's the 30 degrees about?
How do I draw the diagram? The way I am drawing it right now, they never appear to collide?
The oragne ball will be a vector in the negative x direction magnitude 15cm. The green ball has 15cm north+30 degrees east. I would interpret this to be 30 degrees east of north, which would be 60 degrees from the x axis. At the point of collision, the two vectors will be nose-to-nose, so you can start from that point and draw the vectors from there. You can break down the green ball's vectors by making a triangle and using sin and cosin to find each component.
Then conserve momentum in each direction.
remember the i component is (magnitude)cos(angle from + x axis) and the j component is (magnitude)sin(angle from + x axis) then all you have to do is add them, and convert them back into angles and magnitudes (tan^-1 j/i is angle from + x axis, magnitude is sqrt (i^2 + j^2))
Or you can just draw a vector diagram and work it out with sin and cos rules.
So then would this be correct?
x direction:
mv_{1} + mv_{2} = 2mv_{x}
10 + 10cos(60) = 2v_{x}
15 = 2v_{x}
7.5 = v_{x}
y direction:
It remains the same 10sin(60) for m_{2}
I just want to know if I did this correctly :) After this, I would simply have to find the direction and composite velocity for the green ball.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 19 ·
  • · Replies 17 ·
