Consider a planet in some solar system which has a mass double
The discussion focuses on calculating the weight of an object on a hypothetical planet with double the mass of Earth while maintaining the same density. The key equations utilized include W=mg and g=GM/R², where M is mass and R is radius. The gravitational acceleration on the new planet is expressed as g = Y × (GMEarth/REarth²), with Y representing the multiplicative factor derived from the ratio of the radii. The conclusion confirms that the gravitational acceleration can be determined using these relationships, leading to a definitive understanding of weight on the new planet.
  • Understanding of gravitational force and weight calculations
  • Familiarity with the equations of motion and gravitational acceleration
  • Basic knowledge of density and its relationship to mass and volume
  • Proficiency in algebraic manipulation of equations
  • Explore gravitational acceleration calculations for varying planetary masses
  • Study the implications of density on planetary structure and gravity
  • Learn about the effects of radius on gravitational force
  • Investigate real-world applications of gravitational theory in astrophysics
Students in physics, astrophysics enthusiasts, and anyone interested in gravitational theory and planetary science will benefit from this discussion.
draotic
Consider a planet in some solar system which has a mass double the mass of Earth and same density as of Earth . What is the weight of object on the planet in terms of 'W' , where 'W' is weight of object on Earth
W=mg ... density = M / V . ... g=GM/R2
since they both have same density..
i equated their M/V ratios and it gets me the ratio of their radii ..
but it still gets me nowhere
Letting 'D' indicate the information you know for the double sized planet, you know
M_{D} = 2M_{Earth}
and you know R_{D} = X R_{Earth} where X is whatever you determined the ratio between the radii are. So simply find what the gravitational acceleration on this new planet will be with g = {{GM}\over{R^2}}. The trick will be being able to write 'g' as g = Y \times {{GM_{Earth}}\over{R_{Earth}^2}} where you have some constant, 'Y', multiplying the original values known for the Earth. Those known values you know gives g_{Earth} = 9.8 m/s.
You'll have some multiplicative value in front that will tell you how many times stronger or weaker the gravity is.
M_{D} = 2M_{Earth}
thanks , got it
  • · Replies 21 ·
