Consistency of a set of equations
  • Thread starter Thread starter shrabastee
    Set
The discussion centers on the consistency of a linear equation system defined by the equations (q-1)x + py = 0, (1-q)x - py = 0, and x + y = 1. It concludes that if p and q lie between 0 and 1, the system has one unique solution. However, the system will have no solution when the ratio of the coefficients is equal, specifically when p + 1 - q = 0, leading to the condition p = 0 and q = 1. The participants emphasize the importance of using the determinant of the coefficient matrix to determine the solvability of the equations.
  • Understanding of linear equations and their representations.
  • Knowledge of determinants and their role in determining the solvability of linear systems.
  • Familiarity with augmented matrices and row operations.
  • Concept of linear independence and dependence in systems of equations.
  • Study the properties of determinants in linear algebra.
  • Learn how to form and manipulate augmented matrices for solving systems of equations.
  • Explore the concepts of linear independence and dependence in greater detail.
  • Investigate the implications of varying coefficients in linear systems and their effects on solutions.
Students studying linear algebra, educators teaching systems of equations, and anyone seeking to understand the conditions for solvability in linear systems.
shrabastee
(q-1)x+py=0
(1-q)x-py=0
x+y=1
In this linear equation system:
a. if p and q lie between 0 and 1 how many solutions does this system have and why?
b. Ignoring the above condition, find the values of p and q so that the system has NO solution.
Umm..
The equation sets are consistent and yield a non-trivial solution if det A is non-zero, and the equations are linearly independent, right? Or do I need to look at ranks and augmented matrices and all those things?
I was thinking of equating the determinant of the coefficient matrix to 0, to see when they would be inconsistent and hence unsolvable, and i got p=0 that way, but I don't think it's right. I get very confused with this unsolvable/undefined/multiple solutions business, can someone please give me a step-by-step method to check whether a given set of equations is solvable? And also help me with thi sum? Thanks. :)
I suggest you form the augmented matrix and go from there.
Okay, thanks :)
Look at the sum of the first two equations.
What is the "Augmented matrix"?
So the system has infinite solutions, right? Since x+y=1 is the only equation we are left with, once we add the first two?
But what about the second part? When will the system have no solution?
You didn't use the matrix, did you?
No, you have two independent equations. The second one is just the same as the first one, multiplied by -1.
ehild
ehild
Yes, that's what I hoped OP (shrabastee) would recognize after following my hint.
Now, shrabastee, take one of the first two equations along with the third, and solve simultaneously.
So how many solutions does the system have? If p and q lie between 0 and 1 it has one solution, does it? Which I can find by solving them simultaneously. And, they'll have no solution if the ratio of the coefficients of the variables is equal. Is that it?
No I didn't :( Augmented matrices confuse me too much. :(
Yes, there is one solution if p and q are different. There would not be any solution if the denominator was p+1-q=0. Is it possible or not in the range of p and q?
Yes, there is no solution if p=q-1, except in case p=0, q=1. As both p and q are between 0 and 1, it can happen if the interval was meant closed. How many solutions are there if 0 and 1 values are allowed for p, q?ehild
I asked because if you had used one, you would have avoided the mistake of thinking you get rid of both equations when you added the first to the second and got 0=0. Using a row operation on the augmented matrix would have left you with one row of all zeros, but the other two row (i.e., the other equations) would have remained.
ehild
Can I find specific values for p and q? Or does any value of p and q that satisfies the equations q-p=1 qualify as a solution? p and q have no restrictions in this case, they've asked us to ignore the "lies between 0 and 1" condition.
No. As long as q-p ≠ 1 you have a solution. If 0 < p,q < 1 , all values of p,q in that interval give a solution !
shrabastee said:
(q-1)x+py=0
(1-q)x-py=0
x+y=1
Umm..
Ignore one of the first two equations (since one is just the negative of the other). Then, if we have, say (q-1)x + py = 0, and x + y = 1, the system has a unique solution if the determinant of the coefficient matrix [[q-1,p][1,1]] is nonzero, and has either no solution or infinitely many solutions if the determinant = 0; that is a theorem, that holds for general linear equation systems. For 0 <= q,p <= 1 there is just one value of (q,p) that makes the determinant equal to zero, and you have found it: q=1, p=0. In that case the system reads as 0*x+0*y=0, x+y=1. You should be able to see whether we have infinitely many solutions or no solution.
RGV
  • · Replies 20 ·
  • · Replies 32 ·
