Constant acceleration problem with two objects
The problem involves a train accelerating from a station and a passenger attempting to catch up to it after a delay. The subject area includes kinematics and motion analysis with constant acceleration.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the setup of equations for both the train and the passenger, questioning the timing and the relationship between their positions. There are attempts to clarify the conditions under which the passenger must catch the train and the implications of the time delay.
Some participants have offered hints regarding the relationship between the passenger's and train's positions over time. There is an exploration of different interpretations of the equations involved, and a few participants have shared their reasoning and calculations, though no consensus has been reached on the final approach.
There is a mention of the need to consider the timing of the passenger's start relative to the train's motion, as well as the potential for different interpretations of the problem setup. The original poster expresses uncertainty about the provided answer in the textbook.
Portishead
A train pulls away from a station with a constant acceleration of 0.40 m/s^2. A passenger arrives at a point next to the track 6.0 s after the end of the train has passed the very same point. What is the slowest constant speed at which she can run and still catch the train? On a single graph, plot the position versus time curves for both the train and the passenger.
x-train(t)=.20t^2
x-passenger(t)=vt+x_o
I initially supposed that x-train=x-passenger at t=6.0 s but that's clearly wrong. The answer at the back of the book is that v=4.8 m/s but I'm not sure why.
Does the passenger need to catch up to the train before a certain distance, like before the end of the train station?
I don't think so, as it is not given.
Okay. So you need to be careful when setting up your equations here. I will give you a hint: The position of the passenger at time t is equal to the position of the train at time (t-6).
So, wouldn't it be the other way around? Train(t)=.20t^2; Passenger(t)=v(t-6)
When passenger reaches the starting point, the velocity of train is
u = at and xo = 1/2*at^2.
If v is the velocity of the passenger, in time t1 distance traveled by her to catch the train is x = v*t1.
During that time the distance traveled by the train is = x1 = u*t1 + 1.2*a*t1^2
Now x = xo + x1.
v*t1 = 1/2*a*t^2 + a*t*t1 + 1/2*a*t1^2
v = (1/2*a*t^2)/t1 + (a*t*t1)/t1 + (1/2*a*t1^2)/t1
Are you familiar with the differentiation?
If yes, find differentiation of v with respect to t1 and equate it to zero to find the minimum velocity.
rl.blat, can you take an ordinary derivative of that expression? t and t1 are different variables? Also, uh I solved the problem. I minimized v-passenger=x-train(t')-x-passenger(6)/(t'-6)=.20(t')^2/(t'-6) where t' is the time she gets on the train. That function has a relative minimum at t'=12 s if I did my calculus right.
Your answer is correct. In my solution t is constant and is equal to 6 s. There are only two variables, v and t1.
10K
  • · Replies 32 ·
  • · Replies 24 ·
